timing belt cover?
Old Oct 30, 2006 | 02:12 PM
04Gwhiz's Avatar
timing belt cover?
is this it circled in red?how easy or hard is it to remove this cover?
sorry to g352nv..i used his car as an example
Old Oct 30, 2006 | 03:41 PM
DaveB's Avatar
It's not easy at all especially with the engine in the car. As you see, various parts of the accessory system must be removed first. I also believe the front oil pan has to be removed too. Then various bolts are removed from the cover and then it must be pryed off because it's affixed with RTV sealant. Reinstallation requires removing all the old RTV, laying down new RTV, new gaskets, and following a very specfic torque sequence with the bolts.
BTW, it's a timing chain cover, not belt.
Old Oct 30, 2006 | 04:00 PM
04Gwhiz's Avatar
thanks for the info
Old Oct 30, 2006 | 05:34 PM
bbug's Avatar
Are you trying to show off your pretty cam gears? It shouldn't be too hard but I certainly wouldn't recommend it for street driving.
Old Oct 30, 2006 | 07:05 PM
04Gwhiz's Avatar
what do you mean... is it unsafe?
Old Oct 30, 2006 | 07:19 PM
Skyline_G35's Avatar
English dude, English
Well, its not a belt, its a chain. With that, I'm not sure (someone correct me, because this is pure speculation) but the chain might possibly need oil to keep it cool. If exposed oil could spray everywhere?
Old Oct 30, 2006 | 07:38 PM
superchargedg's Avatar
you are right,the chain needs oil for lubrication and cooling.
Old Oct 30, 2006 | 07:59 PM
04Gwhiz's Avatar
i am sorry i am going to polish it..thats what i should have said in the beginning.
D1dphresh
Aug 7, 2015 06:10 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
