Resetting The ECU By Disconnecting The Battery
Old Oct 31, 2003 | 04:48 PM
hoshtaylor's Avatar
Does it matter if you disconnect the positive or the negative before letting it sit for 12 hours...?
"Operator, give me the number for 911!"
- Homer Simpson
Old Oct 31, 2003 | 05:05 PM
Typhoon's Avatar
Re: Resetting The ECU By Disconnecting The Battery
You only need to remove the negative cable for the reset. But, NEVER remove the positive cable - before disconnecting the negative!!!!! And when putting the cables back - ALWAYS put the positive on first, then the negative.
03.5 G35S 5AT - Desert Platinum/Graphite/350Z Tube/Clear corners/HG kit/30% Tint
Old Oct 31, 2003 | 05:21 PM
redwillow's Avatar
20 Year Member
you could get shocked if you pull the positive before the negative. Just FYI, my stereo did NOT recognize 4 of 6 cd's after i reconnected the battery, i suggest unloading any cds from your changer before you disconnect.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Oct 31, 2003 | 05:35 PM
hoshtaylor's Avatar
Thanx for the updates guys...putting in my K&N today and wanted to reset my ECU tonight...
- Homer Simpson
Old Oct 31, 2003 | 08:03 PM
Meatshackle's Avatar
Deep Sea Moderator
Also put your windows a little bit if not all the way down before disconnecting the battery if you think you might be needing access to your car.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
happydays888888
Oct 6, 2015 06:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
