HELP engine wont start after aem air filter install
Old Nov 17, 2006 | 01:01 AM
46.5quartermile's Avatar
First i checked the mass airflow sensor and it wasnt all the way plugged in so I plugged it all the way in then did an ecu reset. Now when I start the car it revs up like normal for a about a second then boggs down quickly. I cant figure it out does anyone know whats wrong?
Old Nov 17, 2006 | 01:11 AM
Derek S's Avatar
you messed up your idle, when you start the car play around with the gas peddle and get it to the dealer they will fix the idle, takes about 5-10 min. o and make sure you take the intake off and if they ask you anything tell them you have no idea.
Old Nov 17, 2006 | 01:15 AM
It wont even start enough for me to play around with the gas. There has got to be another way.
Old Nov 17, 2006 | 01:22 AM
Derek S's Avatar
there is a DIY for reseting the idle but i have never done it so i don't know what it exactly is maybe someone else on the bored can help you with that or maybe try a search.
Old Nov 17, 2006 | 01:59 AM
Yeah the DIY is for adjusting the idle but I cant even get the car running for 3 seconds to adjust it.
Old Nov 17, 2006 | 02:24 AM
O HELLA JDM's Avatar
did you try to put the stock back on...try that and see if that works....then after try puttin on the aem agian..that might work...or check the valve cover next to the plenum...did i spell that right...see if there is a air leak around there...but good luck with that...
Old Nov 17, 2006 | 02:33 AM
Nope no leak. Im pretty sure it has something to do with me initialy starting the engine without the mas completely plugged in.
Old Nov 17, 2006 | 03:38 AM
G352NV's Avatar
Never enough
Sounds like a vacuum leak.
Old Nov 17, 2006 | 07:41 AM
Speedoholic's Avatar
G (enie) FUNK ERA
If it starts and immediately shuts down I'll bet my money you either have some that's blocking airflow in the intake (although very unlikely), or more probable: faulty MAF sensor. Do you have a recently installed aftermarket intake? If so, take it out, if not, take it to the dealer.
Old Nov 17, 2006 | 08:37 AM
cato's Avatar
SouthernComfort Moderator
I have taken the MAF off several times, started the car without having it plugged in. It will throw the SES light. You can clear the computer with the pedal reset method. Or if you don't know how to do that, you can pull the negative battery terminal for 8-16 hrs. I would suggest a computer reset as step one.
Stealer as step never! with an aftermarket intake problem
Old Nov 17, 2006 | 01:24 PM
Yes I just put in an AEM intake. I did do the pedal reset and still nothing!!!!!!!!! AHHHHH I cant even drive it to the dealer if I wanted to.
Old Nov 17, 2006 | 01:27 PM
madchef's Avatar
Go back to stock, and see what happens.
When you start the car, does it die if you step on the gas? Def a sign that the MAF sensor is dead
Old Nov 17, 2006 | 01:29 PM
Yeah it dies right away no matter what I do. Crap I was hella careful with the maf.
Old Nov 17, 2006 | 01:35 PM
madchef's Avatar
Just go back to stock, and get infiniti road side assistance to take it to the dealer. They should fix it under warranty
Old Nov 17, 2006 | 01:52 PM
FIggured it out I had the MAS pointing the wrong way. The aem photos were in black and white and blurry on top of me being a dumb ***. THanks guys for the help.
