Engine Cover
Old Nov 24, 2006 | 04:24 PM
jtunello's Avatar
Engine Cover
Is it allright to leave the engine cover off?
Old Nov 24, 2006 | 04:33 PM
tragedycat's Avatar
Yes, makes no difference in terms of heat.
Old Nov 24, 2006 | 04:37 PM
Calvin's Avatar
Overglorified Altima
yuup. thats all it is...an engine cover
it doesnt really serve a purpose...i took mine off a couple weeks ago
you might wanna check this thread out...
https://g35driver.com/forums/engine-drivetrain-forced-induction/118241-who-goes-without-engine-cover.html
g/l
Old Nov 25, 2006 | 10:04 AM
Earl's Avatar
Your test results are opposite of mine. Did you also go to The Clueless One's school of advanced heat transfer?
Old Nov 25, 2006 | 10:50 AM
KPierson's Avatar
My engine cover has been sitting in my basement for about two years now.
Old Nov 25, 2006 | 12:32 PM
bbug's Avatar
Yes, it's OK. It's main purpose is noise suppression.
Old Nov 25, 2006 | 01:27 PM
madchef's Avatar
Wow, great reply...
Plenty of people have done tests showing no increase in engine heat soak with the cover on....so what makes your majestic tests so wonderful?
Old Nov 25, 2006 | 05:12 PM
GreenGoblin's Avatar
The goblin resurrection
I am gonna keep mine on I like how it looks
Old Nov 27, 2006 | 03:09 PM
FenixL1P's Avatar
through my experience, with the cover on, my upper plenum is hotter to the touch than without, especially after a 2 hour highway drive..... so cover has been off except for when i need to take it to dealer...
Old Nov 27, 2006 | 08:57 PM
DaveB's Avatar
Bingo.
Old Nov 27, 2006 | 09:42 PM
ttrank's Avatar
Grocery getter
Take it off.
Old Nov 27, 2006 | 10:07 PM
zazaracing's Avatar
Team Transport Member
Originally Posted by madchef
Wow, great reply...
The engine cover traps heat under there for increasing the intake temps. I along with many people have track tested it with sensors and data logging. Just look on the motodyne site or ask Tony he will give you proof.
Old Nov 27, 2006 | 11:17 PM
VQguy's Avatar
I had this same question myself a few months ago. After conversing with a few of my friends I decided to pull my cover off and have had no negative side effects so far. I say take it off
Old Nov 27, 2006 | 11:32 PM
gary c's Avatar
Engine cover.............gone!
After installing my MotorDyne 1/2" space I didn't
have a choice. So....I found a MF 350Z cover on
line, cut to fit my plem and had it painted my cars
color....Twilight Blue. It only covers the front 1/3
of my plem so I don't have issues with heat........
just looks cool!
Old Nov 28, 2006 | 01:46 AM
DaveB's Avatar
I've done datalogging with and without the cover and saw no measurable difference. When the intake manifold heat soaks, it doesn't matter what's on top of it. The FM chassis engine compartment is a tight fit and the engine heat soaks quickly because of the low hood, close shock towers, and underbody tray. That plastic cover isn't going to trap any more heat than the hood will. If anything, the alum hood may radiate more heat back onto the manifold than the plastic cover.
