Strange Rattle at slow speed
Old Dec 9, 2006 | 11:10 PM
rob04's Avatar
Hello,
I tried searching for this, but since it is difficult to try to describe I figured I would try a new post.
I've got a 2003 AT sedan. In the morning I put the car in reverse back out of my driveway then put the car in drive and drive off. Now when I get maybe 50 - 100 feet down the road at approx 10 - 15mph I hear the rattle... it typically lasts for about a second and goes away.
To describe it, it sounds like a gear rattling or being released and lasts for a second or two and goes away. It's a loud metallic rattle that seems to be coming from the front end of the car. It goes away immediately and I typically don't hear the rattle when the car is warm.
Any insight into this would be appreciated, it's quite an annoying noise, not to mention I'm a bit concerned that I may be doing further damage to some component by not addressing it...
Thanks in advance
Old Dec 10, 2006 | 12:40 PM
Gordgee's Avatar
Administrator
It sounds like your ABS self-check. Normal.
Old Dec 12, 2006 | 08:54 PM
midnightrunner's Avatar
You know i have the same rattling sound that goes away, but it sounds like its coming from the rear. is this the same problem?
Old Jan 12, 2007 | 09:34 PM
rob04's Avatar
Hmm abs self-check interesting... haven't heard of that before...
It's a quick rattle... almost sounds like the timing chain rattle.... just really strange to happen at the time it does to be the timing chain....
Quite annoying though but thanks for the response
Old Jan 12, 2007 | 09:37 PM
ISMSOLUTIONS's Avatar
Sounds like a loose belt and your hearing it rap on something...check your belts...
Rick
Old Jan 13, 2007 | 05:57 PM
CBRworm's Avatar
20 Year Member
ABS self check. If you have your foot on the brake pedal when it does it you will feel it pump up. It should do it once each time you start the car the first time you hit 10-15 mph.
Old Jan 18, 2007 | 02:35 PM
Kensi's Avatar
to me it kinda likes like a BOV =)
Old Jan 20, 2007 | 07:06 PM
Godfather's Avatar
in the mornings, i usually get a noise from the engine..its sorta like gas is being released...but thats for a sec aswell...i'm thinking if we're talking about the same problem here....
It does it end of first gear when going slow...
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
aaron3719
Sep 29, 2015 10:12 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
