Whining noise comming from engine compartment
Old Apr 6, 2007 | 04:40 AM
accordfreak's Avatar
Originally Posted by Aznteazer
im taking my car in today for the whining/whirring noise in my engine bay.
it only happens in the first 5 minutes of driving after it's been parked for a long time.
im leaving it at the dealership and going back next morning and have a ride along with a technician.
hopefully i'll get a new tranny.
I had the same noise driving the first 10 minutes during warm up. The pitch of the whining/whirling noise changes as you increase your speed. When you coast on neutral the sound goes away but one you put it back in gear the noise comes up. Dealership confirmed it was the tranny. Got it replaced no hassle no problems.
sorta sounds like this guy lol
Old Apr 6, 2007 | 09:35 AM
AthensBlueG's Avatar
Brian
I have a whirring/grinding noise that occurs within the first 10 seconds after I start accelerating, and just like you, it only occurs after the car has been parked for a while. It's like a gearbox grind or something, and lasts for the same 2 seconds each time, and then it goes away. It happens every morning when I start moving the car out of the driveway. I have an Auto. I figure it's normal?
Old Apr 6, 2007 | 09:48 AM
MsA's Avatar
MsA
I have a whining noise in my engine bay too!!!
Old Apr 6, 2007 | 04:39 PM
Aznteazer's Avatar
took it for a ride with a tech today and he finally heard the noise.
he has to diagnose it further but told me if he had to change out the tranny, i'd have to put my stock exhaust back on or else they'll charge me extra or something.
is this how it is??
accordfreak, which dealership did you go to?
Old Apr 6, 2007 | 06:07 PM
is this how it is??
nice. glad they heard the noise. They SHOULD change out the tranny with that noise. There's nothing really to diagnose. I went to Frontier infiniti in santa Clara. nor cal..
Old Apr 12, 2007 | 12:09 PM
DBinDC's Avatar
I've had this happen to me, wound up just being low on oil. Before I figured out what it was it would just happen for the first ten minutes, and like you said would go away when you were coasting. I thought it was coming from the transmission at first, but then it got really bad, whined continuously. Didn't think it was oil because it didn't knock like other cars, but actually found the answer after searching this board. Check the oil
Old Apr 12, 2007 | 01:28 PM
f r e z N Y's Avatar
Originally Posted by DBinDC
Check the oil
I've checked before, and it is not the same problem I am having. I suspect that the belt has gotten loose. It only happens when it is warm enough outside. Possibly allowing the belt to "stretch" more.
Old Apr 12, 2007 | 09:59 PM
hotsand5's Avatar
Originally Posted by Dubfound
I get this kind of noise when my car is cold. Like 20 or 30 out. But after the car gets hot it goes away.
--I have EXACTLY that same problem. Did you take it to the dealer to see what it might be?
Old Apr 14, 2007 | 09:26 PM
Aznteazer's Avatar
i changed my belts b4 i took my car into the dealership since i had the UR pulley and it wasn't the belt.
the dealer confirmed it's the tranny. (in my case anyway)
Old Apr 15, 2007 | 10:17 AM
CBRworm's Avatar
20 Year Member
My alternator whines pretty loudly in the morning. I found it by listening with the skid plate removed. It goes away after a while. It sounds exactly like the alternator whine you would get through an aftermarket stereo that is not grounded right - but comes from the alternator body.
Old Apr 15, 2007 | 12:31 PM
Chrlesmd's Avatar
Yeah, and it gets louder as the RPMs go up... .
Old Feb 16, 2011 | 12:53 PM
Xx2006GCOUPExX's Avatar
hey for the tranny replacement when you went for a ride along what happened was the temperature cold or just the car
rezendvous420
May 31, 2020 01:26 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
Joshua615
Aug 31, 2015 12:29 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
justgotg35
Jul 19, 2015 12:33 PM
