GReddy V-manage (Variable Valve Timing Controler)
I Was Checking GReddy Website and i just found that they came up with this device and here is the Information for it
V-MANAGE (VARIABLE VALVE TIMING CONTROL UNIT)
Part No 15500551
* Freely adjust valve timing on Variable Valve Timing vehicles.
* Fast USB data communication.
* Simultaneously data log with e-manage Ultimate.
* DIP switches available to activate and deactivate maps. Turing all dip switches off will return cam timing to stock.
* Up to 4 channels available. (V-type and boxer engines).
* Adjust VTEC and VVTL-I crossover points.
<MAP>
* Valve Timing MAP ? 16x6 MAP to input valve timing.
* Valve Timing Adjustment MAP ? 16x16 MAP to adjust valve timing.
* VVL MAP/VTEC MAP ? 16x16MAP to adjust crossover points.
<Data Logger>
* Valve Timing (ECU), Valve Timing (MAP) and Valve Timing (Measured) display.
* VVL, VTEC ON / OFF display.
SUPPORTED VEHICLES
TOYOTA
VVT-i : 2JZ, 1JZ, 1SZ,2NZ,1MZ,1NZ,1ZZ,3S,1G,2AZ
VVTL-i : 2ZZ-GE
DUAL VVT-i : 3S-GE
SUBARU
AVCS : EJ207
HONDA
i-VTEC : K20A
NISSAN
CVTC : VQ35DE (except Z33 anniversary)
MITSUBISHI
MIVEC : 4G63
for more info check these links
http://www.trust-power.com/03electric/vmanage.htm
http://www.trust-power.com/03electri...t_vmanage.html
http://www.trust-power.com/06new/e20...6_vmanage.html
http://www.trust-power.com/06new/e20...e_harness.html
MSRP is 50,000 JPY = $417
Available March 2007 according to http://www.mohdparts.com/emanage/index.html
Part No 15500551
<MAP>
<Data Logger>
SUPPORTED VEHICLES
TOYOTA
VVTL-i : 2ZZ-GE
DUAL VVT-i : 3S-GE
SUBARU
AVCS : EJ207
HONDA
i-VTEC : K20A
NISSAN
MITSUBISHI
MIVEC : 4G63
