What performance mod next?
Old Mar 2, 2007 | 12:55 PM
clinthammer's Avatar
Since I have a 5at i think im limited to mods under 1k (too early for TT kit).
Right now I've got:
5/16 MD plenum spacer
z tube
jwt pop charger
in next 10 days:
gordgee grounding kit
other mods:
tint
clear corners
hyper white clean corner lights, rear license plate, trunk light
UTR medium rear lip
I don't need rims now cuz its too costly to ship to Dubai. I will bring them back to me in luggage when I go to FL in June (works vs-xx).
I guess the next is a HKS/Borla exhaust + coupe mid pipe?
Old Mar 2, 2007 | 01:32 PM
Demonteverde's Avatar
Moderator
You should add high flow cats to your list....
Old Mar 2, 2007 | 01:42 PM
Calvin's Avatar
Overglorified Altima
+1 for high flow cats.
Old Mar 2, 2007 | 01:46 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
get some FI hi-flow cats, coupe middy, and an HKS rear section and you'll have one sexy a$$ exhaust note.
-GP-
Skaterbasist's Avatar
Retired SuperMod
First thing that came in mind after the usual mods was HFC...
Old Mar 2, 2007 | 01:51 PM
Retired SuperMod
Also, have thought about Mrev2?
I would also highly recommend a tune after the HFC & Mrev2.
Old Mar 2, 2007 | 02:35 PM
extreme4377's Avatar
Lexus IS350
-GP-
+1... or some FastIntentions HFC or Test Pipes and when the FI sedan exhaust comes out, that will be a killer combo.
Old Mar 3, 2007 | 07:30 PM
OCG35's Avatar
a lot of people are mentioning FI cats instead of Crawford... any reason?... Cost? Performance?...
Old Mar 3, 2007 | 07:32 PM
izmir41500's Avatar
G35driver Addict
Mrev2
Old Mar 4, 2007 | 02:33 AM
Calvin's Avatar
Originally Posted by izmir41500
Mrev2
5at = non revup = 5/16" spacer + mrev2 = tune
Old Mar 4, 2007 | 03:34 AM
Lexus IS350
Cost, performance, quality, customer service, sound...etc. The list goes on. You really cant beat the FI products on any level so to speak
Old Mar 7, 2007 | 10:11 AM
Crashtest77's Avatar
I was told not to do the plenum space and the mrev2 on non rev up engines. Can someone clarify this for me. Was told the car would run lean,or leaner...I like the fi exhaust just don't like the price.
Old Mar 7, 2007 | 11:11 AM
OCG35's Avatar
It's not that you can't do it... Spacer is a must have! MREV2 in addition to spacer is not bad, but you probably won’t see too much additional gain (to spacer alone)... as far as running lean - I thought so in theory as well, but there are several posts from Tony (at Motordyne) that indicate it varies car to car... you will need a dyno with AFR to determine.
I have 1/2" spacer (with a few other things) and have been extremely pleased! Highly recommended.
Old Mar 7, 2007 | 09:00 PM
Okay,because the last thing I want to do is screw something up with this car. I will try the plenum spacer,and see how that works,and then go to the mrev2,and what should I do then? Get a whole new reflash or just get the car tuned somewhere that can play with the ecu? Not sure of who around the east coast jersey area that can do the reflash.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
RWDguy4238
Sep 30, 2015 12:13 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
