mrev2 and 5/16 spacer??
Old Mar 12, 2007 | 02:52 AM
minh420's Avatar
Im about to install the mrev2 and 5/16 spacer on my 04 6mt non rev up coupe. My current mods are stillen td and injen cai and technosquare reflash. Does anyone know if i will need to reflash my ecu again?? I think i have the basic technosquare reflash. How can i tell if my car is running lean after i install the mrev2 and spacer. Thanks in advance!!
Old Mar 12, 2007 | 02:59 AM
Skaterbasist's Avatar
Retired SuperMod
Well, you definately should have waited for the tune after these mods.
Not sure if you need to reflash your ecu though; Someone else should know the answer.
Old Mar 12, 2007 | 03:02 AM
Calvin's Avatar
Overglorified Altima
i think technosquare will reflash it again for only 150.
chances are, youll need to again.
Old Mar 12, 2007 | 03:45 AM
G05C's Avatar
I just got my car custom tuned by TS last week. You don't necessarily HAVE to get it tuned again. If I were you, I'd wait until I installed another performance mod (if you're planning on modding more), then get it tuned. And hero is right, it's 150 for your next tune.
Old Mar 12, 2007 | 07:39 PM
minh420's Avatar
thanks for the info guys. just installed the mrev2 and 5/16 spacer and it pulls harder now and sounds great. Doesnt seem to be running lean but what is a for sure way to tell? The only difference i can tell is i idle just a little lower now. Technosquare raised my idle to about 800 rpm. I think. but now i think it idles aroun 700 to 750. Any thoughts??
Old Mar 14, 2007 | 01:35 AM
papiloco21's Avatar
get a dyno with A/F meter to be safe, or you can install a wideband a/f guage in your car.
Old Mar 14, 2007 | 01:48 AM
gary c's Avatar
Why..........?
Did you ask Tony at MotorDyne about the Mrev2 with the '04 G? It is my
understanding it isn't needed with the '03/'04 models. The spacer will make
a major diffrence from idle to redline.
Old Mar 14, 2007 | 01:50 AM
hai109's Avatar
^^^He's right...The MREV2 is made only for the REV-UP motor...
Old Mar 14, 2007 | 09:15 AM
G35kidd's Avatar
I have an 03 and I'm thinking of getting either the 5/16 or 1/2 spacer and MREV, but according to hai109, the MREV isnt made for non revup?
Old Mar 14, 2007 | 11:24 AM
papiloco21's Avatar
tony once replied to me in a PM that the mrev2 MAY be used on a non-rev up motor, the gains wont be as significant as a rev-up motor though.....also it had a greater possibility of running lean but this varies by car..... the lower plenum (someone correct me if im wrong) is just the non-revup up plenum slightly modified no?
Old Mar 14, 2007 | 11:59 AM
hai109's Avatar
You can just get the spacer...There are older MREV kits that will work on your older model. I don't think Tony sells the older kits anymore...I could be wrong...
PM him and ask...He's a very nice guy. I met him at Autocrave...
Hydrazine
Old Mar 14, 2007 | 05:30 PM
minh420's Avatar
do a search. mrev2 is for revup and nonrevup motors. On non revup you need a tune if u run spacer and mrev2.
Old Mar 14, 2007 | 05:32 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you are 100% correct.
-GP-
Old Mar 14, 2007 | 05:34 PM
Tony made a thread with dyno's on the non-revups and revups with MREV2, MREV2 is compatible with both revup and non revup, it will have a bigger impact on revup's but will also make a significant improvement on a non revup if you get the A/F ratio tuned.
-GP-
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
