So is there any gains with SAFC proof please
Old Mar 26, 2007 | 12:10 AM
infinitialex's Avatar
I heard that some member gained a significant amount of power from tunning with SAFC, yet no conclusive dyno numbers of before and after.
Please all you with SAFC tuned VQ motors please post your numbers and expiriences with SAFC.
Old Mar 26, 2007 | 09:42 AM
mr freeze's Avatar
ask and you shall receivehttps://g35driver.com/forums/engine-drivetrain-forced-induction/134210-car-got-dyno-d-today.html
Old Mar 26, 2007 | 09:48 AM
izmir41500's Avatar
G35driver Addict
Originally Posted by mr freeze
the op posted and asked questions in this thread. I think he's looking for more info. i'd like to see the A/F and tuning chart/set point settings on the SAFC. I've heard good things about the SAFC on my.is but haven't really seen one on a G35 till now.
Old Mar 26, 2007 | 10:35 AM
trey.hutcheson's Avatar
Maybe NISMO G will chime in here, I know he has one. I don't know if he dyno'd before and after, but it's hard to argue with his 1/4 performance.
Old Mar 26, 2007 | 01:50 PM
common people post more info....
mrfreeze i already asked you for more info on af ratio and settings on safc you never answered.
Old Mar 26, 2007 | 06:55 PM
i just got safc2 black but i have no clue how to install it since i cant find the wire diagram fro my g35
can anyone help with this please?
Old Mar 26, 2007 | 07:08 PM
izmir41500's Avatar
G35driver Addict
did you try contacting apexi or whoever you bought it from?
Old Mar 26, 2007 | 07:09 PM
i bought it used,, on apexi site there is no info on g35 motor installation
Old Mar 26, 2007 | 08:05 PM
xxmotox2's Avatar
i have one in my g, my guy followed the z33 diagram but hat to test a few wires cuz they didnt match.
Old Mar 27, 2007 | 12:09 AM
Can you please provide your current setting on your SAFC, hight throttle, low throttle and other setting that you can find. Many members here including myself would like to know how and to what extend our cars need AF corection.
Thanks
Old Mar 27, 2007 | 07:22 AM
clifftrail's Avatar
Using someone else's settings is a bad idea. Every car reacts differently and where you live will also factor in. Get a wideband or take it to a dyno and tune it safely.
Old Mar 27, 2007 | 12:18 PM
DUH,,,, no one is planning to use anyones settings. SAFC tune is defenitly car specific and no one should try to put someones settings in their car ,its way too easy to destroy the engine this way.
I just wanted to get a general idea of how much corection might be neded for these engines and also if low throttle can be tuned too, as in many cars you can not override low throttle only high. Factory ecu overrides any correction that you make on low throttle and over time it adjusts af ratios to how it was before.
Old Mar 27, 2007 | 12:27 PM
Jeff92se's Avatar
Red Card Crew
A thought. Before you use one. You need to see WHERE you need adjustments. In order to do that, you need to be able to see your a/f ratios. Either a dyno or an OBDII datalogger. THEN you can start playing around with the adjustments. Just fiddling around with the adjustments without any data before hand has about a 90% of failing vs success.
Old Mar 27, 2007 | 02:04 PM
well YEA,,,, of course i have to see AF ratios first.
My plan was to take it to a dyno, but as Im thinking now maybe some obd2 monitoring datalogger would work better for me in case i want to redo adjustments later if I add any more mods. I have never used one though and im not sure if they are as acurate as dyno or wideband. ANyone use dataloggers to tune????????????
Old Mar 27, 2007 | 02:11 PM
With an 03, a OBD2 tool won't help your monitor a/f's. You'll need a dedicated wideband. or dyno time.
