engine beauty cover
The engine cover doesnt trap much heat at all, it is designed to trap some residual heat so your hood does not lose its color or chip the clear coat too soon. When your car is moving the air passing by moves the heat out, you can see the front is curled down and the rear has more of an angle to block the heat from ultimately rising and enough incline to not restrict the passage of the air moving allowing the plenum to stay at normal operating temperature.
Originally Posted by Pska
our engines are ugly tho
like ttrank said.. doesnt trap enuf heat to affect perfromance.. id keep it on for a few reasons
1. keeps the ugly plenum out of sight
2. stealth like
3. keeps the engine/plenum clean
4. doesnt affect performance
