Kinetix Plenum Install Question PITA Gray Plug
Old May 11, 2007 | 03:27 PM
k1200s's Avatar
I just got the Kinetix Plenum and was installing it, and everything was going great until I got to the step that said "unplug the gray plug from the throttle body." Sounds easy, except that thing is on really tight and it looks electronic which usually means fragile, so I am afraid to pull on it too hard or pry it off. Does anyone know how to get if off, is there some clip I am supposed to push, or is there a trick. Please let me know otherwise it is $170 to get a mechanic to do it and it really looks easy, except for that PITA plug that won't come off. Thanks for your help.
Old May 11, 2007 | 05:04 PM
88G35's Avatar
I do not have my car around to get a pic and show you (in the body shop) but there is a tab your suppose to push down to release the two connectors. I am not sure which side it is on I forget but there is a tab you need to push down to release the two connectors. If you do not have the throttle body off already then you might need to take it off to locate it. If you can't get it off still then PM me and I will be happy to work with you on it.
Old May 11, 2007 | 10:10 PM
k1200s's Avatar
Thanks you very much. My second plenum was shipped today. The first one was cracked by the mechanics when they overtightened the bolts, so this time I am doing it myself. I will let you know how it goes. I appreciate knowing I have some support.
jsimonk
Dec 22, 2023 03:49 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
