Spring Maintenence Info
Old Mar 26, 2007 | 02:51 PM
b1gs's Avatar
i wanna do a radiator flush, but unfortunetly do not have a maintenence manual.
do we put a 50/50 mixture of coolant with water, or just the coolant?
also, i wanted to change the fuel filter, where is it?
Old Mar 26, 2007 | 03:04 PM
richie's Avatar
50/50 mixture of coolant and DISTILLED water
not sure about the fuel filter
Old Mar 26, 2007 | 03:05 PM
b1gs's Avatar
by this you mean that the water you use in the 50/50 mixture to be distilled right?
Old Mar 26, 2007 | 05:39 PM
sliderg35's Avatar
You can buy pre-mixed coolant at any auto store as well. You'll need 8.5 litres.
Old Mar 26, 2007 | 05:50 PM
b1gs's Avatar
yeah ive used that before, its probably cheaper to just buy the concentrated stuff and mix it yourself, especially if your using alot of it. Just wanted to make sure the g35 were 50/50.
does anyone know about the fuel filter, i heard somewhere its in the gas tank, is this true?
Old Mar 26, 2007 | 08:03 PM
Chrlesmd's Avatar
Definately 50/50. It's the 50% water that cools your engine. Definately use distilled water as well since tap water has impurities.
Old Mar 27, 2007 | 07:12 AM
superchargedg's Avatar
we have a non serviceable fuel filter located in the gas tank.it is attached to the fuel pump.
Old May 12, 2007 | 11:07 PM
HiTechOilCo's Avatar
Make sure you use the special flushing equipment needed to do the job so you don't spread poisons around and get in trouble with the authorities too. It's illegal to just dump antifreeze down the storm drains, or what have you.
Old May 13, 2007 | 08:29 AM
Q45tech's Avatar
If you change annually you can use less AF concentration in Summer and more in winter [sufficient for temperature].
In Summer a 20% AF might be acceptable in heat is a problem.
Don't confuse boil over after shut down with running temperature.
g.spot
May 9, 2016 10:54 PM
TurTLe*
Sep 29, 2015 01:43 PM
carsmacked71
Sep 18, 2015 04:13 AM
DRG35R
Sep 16, 2015 05:33 AM
