ECU resetting
Old May 2, 2007 | 01:37 AM
xcessiveskllzz's Avatar
Turbo G35 coupe single turbo with some goodies
ECU resetting
Is it better to reset the ecu after mods on the g35's or it doesn;t matter if you reset? would you gte more gains from your mods if you do or doesn;t make a difference? Anyone with info get back at me.
Thanks,
Desh
Old May 2, 2007 | 09:35 AM
rcdash's Avatar
never know till you try. you will erase learned fuel settings, which may be good or bad depending on how good the settings were...
Old May 2, 2007 | 05:59 PM
ttrank's Avatar
Grocery getter
The car will adapt over time but a reset will get it started faster.
Old May 13, 2007 | 05:53 AM
nice feedback
Old May 13, 2007 | 08:26 AM
Q45tech's Avatar
The are 3 levels of memory: One resets in 1 minute, the second takes about 5 minutes and the block learn for emission testing requires a few starts and or 50 miles of cruising on highway.
Because the vehicle must be adapable for sudden changes in mountains [altitude/temperature] or weather conditions.
OBD2 adapts fast in typical conditions.................resets of memory are not necessary unless you are replacing a failed sensor which has locked in a code.
Just drive a few miles.
Old May 13, 2007 | 12:25 PM
good to know q45tech
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
