Interior Air Filter (In-Cabin Filter)
Old May 15, 2007 | 04:07 PM
RamboRami's Avatar
G35driver.com Moderator
Thumbs up Interior Air Filter (In-Cabin Filter)
Just installed the Nissan branded activated-charcoal air cabin filter and it works great! No Smells!! Construction is superior to Gordgee's home-made charcoal/hepa air filters and price is slightly cheaper.
Sorry Gordon!!!! I still <3 you
Old May 15, 2007 | 04:11 PM
Jeff92se's Avatar
Red Card Crew
Okay? How much and which Nissan dealer did you buy from?
Old May 15, 2007 | 05:08 PM
g35rcr's Avatar
i got one last time for 35 dollars
Old Jun 14, 2007 | 06:06 PM
moe's Avatar
moe
part number needed? I like the no smells part, dang skunks drive me nuts if i forget to hit the recirculate button lol
Old Jun 14, 2007 | 06:29 PM
Mapester's Avatar
I don't know, every time I get my air filter replaced the smells go away for two weeks then come right back. Annoying!
Glad it works for you at least
edit: Wait, I didn't realize this is an aftermarket filter your talking about, ill be curious to see if it continues working longer then the oem one...
Old Jun 14, 2007 | 08:20 PM
dunglan7's Avatar
Are you talking about the same carbon filter Riverside is sell for about $60. Where did you get one for $35 dollars at?
Old Jun 16, 2007 | 04:27 PM
Gordgee's Avatar
Administrator
No problem Rambo.
Your 1st Filter from April 2004 was an early production model. There were improvements made, even since mid 2005.
As a secondary product line to GroundingGear® Hyper-Ground Systems, I don't mind bowing to the competition. I still don't believe however, that the Infiniti Filter is actually HEPA rated, nor does it have the surface area of mine. I still <3 you too!
Old Jun 16, 2007 | 04:43 PM
Gordgee's Avatar
Administrator
The filter isn't actually what causes the odour. It's the mold/mildew present and growing on the heat exchanger coils. When you run the A/C, moisture condenses on them resulting in the odour. If you let your fan run on high for a few minutes with the A/C off to dry off the coils prior to shutting off the car, most of the odour when you start up again won't be there.
What I recommend in my instruction set is:
After OEM filter removal, use a commercial A/C deodorizing spray or Lysol Neutra-Air Spray or similar disinfectant (Isopropyl Alcohol can also be used as an odourless spray) to deodorize the A/C system prior to new filter installation. With the fan on Hi, spray the air-box and into the ducting. Let fan run for 3 to 5 minutes with windows open to circulate the disinfectant / deodorizer to kill moulds and mildew.
I routinely use 99% isopropanol in one of those pump things that are sold in kitchen stores to spray cooking oil (I keep a new one just for this purpose) and spray it into the air-box. A commercial A/C conditioner works as well, but some find the smell to be objectionable. It should kill the mold/mildew in the heat exchanger and keep it odour free for a much longer period of time, and if the filter seals and filters adequately, outside spores won't have as much of a chance to re-deposit on the coils.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
JG_G35
Sep 7, 2015 09:35 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
