engine bogging down after spacer and pop charger install??
Old May 19, 2007 | 10:07 AM
hellomynamesnye's Avatar
i noticed since i installed the motordyne 5/16" spacer and jwt pop charger yesterday that when im driving normally and depress the clutch pedal to slow down, the tach goes all the way down to about 300-400, the engine bogs slightly, then immediately raises back up to the normal 600 or so level. has anyone else experienced this after making these installs??
Old May 19, 2007 | 10:24 AM
Andy2434's Avatar
Be sure to check that everything was reinstalled and tightened properly. You may have a vacuum leak. I have had no issues with your said mods.
Old May 19, 2007 | 10:31 AM
everything was definitely reinstalled correctly, i didnt have a inch/lbs torque wrench, so i used a nut driver with a 10mm socket on it like few other ppl on here stated they used. maybe ill just try to retighten them.
Old May 19, 2007 | 10:52 AM
just went outside and rechecked the tightness on all the bolts, they all had loosed up noticebly since yesterday. i tightened them back up with the nut driver again. does it take a couple days for it to seal up properly where i wont have to keep retightening them?
Old May 20, 2007 | 01:20 AM
Jeff92se's Avatar
Red Card Crew
The 2nd retorque should be good enough. Has the idle improved?
Old May 20, 2007 | 10:59 AM
DaveB's Avatar
The rpm drop tells me you've got a slight vacuum leak somewhere. You should really invest in a inch/lb torque wrench. I think MD's recommendation is 70 inch/lbs, but I found that 100 in/lbs is needed for the 6 center bolts. 70-80 inch/lbs wouldn't hold after 5 heat cycles. You really need an inch/lbs torque wrench to do this the right way because you risk snapping the soft manifold bolts.
Old May 20, 2007 | 11:30 PM
yeah, the bogging problem is fixed. in addition to retightening the bolts, i also cleaned my TB and MAF. actually, the motordyne manual states a nut driver is ok to use since the most force you can put on that with 1 hand is about 100 inch/lbs....but i agree i need to find a inch/lb torque wrench, im just not sure where to get one.
jsimonk
Dec 22, 2023 03:49 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
chinee
Aug 8, 2015 10:11 AM
avalino
Aug 6, 2015 01:42 PM
