for NY 5w30 or 10w30
Old May 30, 2007 | 03:40 PM
HiTechOilCo's Avatar
Originally Posted by ebuy929
0w30... is that safe? sounds off.
ok lets clear things up............. i am purchasing oil at autozone or strauss... lol..
Ahhh...the low priced stuff.
Steve
CEO of Hi-Tech Oil Co.
Distributing industry leading AMSOIL synthetic lubricants for 19 years
Old May 30, 2007 | 03:41 PM
ttrank's Avatar
Grocery getter
Originally Posted by HiTechOilCo
The oil filter with the greatest filtration capacity that will filter down to the smallest dirt particles possible to prevent needless engine wear. Ea oil filters lead the industry, followed by Mobil 1 and possibly then Purolator. Don't spend $4.50 for an oil filter to, "protect", an egine worth thousands. Penny wise and pound foolish.
Steve
do you have any specs on the oem filters?
Old May 30, 2007 | 03:49 PM
how many qts do i need to buy,,,, 5 or 6
i have a 2006 6mt
The engine takes 5 quarts, but if you only purchase that amount, then you have no extra oil to top off with as the engine consumes oil and any engine will consume oil. This is normal. Not ideal to be caught far away from home, possibly after store hours with an expensive engine running low on oil. I'd recommend purchasing at very least 7 quarts, if not 8, and keep the extra oil in the trunk so you have it readily available as needed.
Steve
Old May 30, 2007 | 04:15 PM
Using an O.E. oil filter in extended drain service might not be advisable.
The below may be of interest -
"Absolute Efficiency
AMSOIL Ea Oil Filters have the best efficiency rating in the industry. EaO Filters provide a filtering efficiency in accordance with industry standard ISO 4548-12 of 98.7 percent at 15 microns, while competitive filters containing conventional cellulose medias range from 40 to 80 percent efficiency.
Less Restriction
AMSOIL Ea Oil Filters have significantly lower restriction than conventional cellulose media filters. Their small synthetic nanofibers trap smaller particles and hold more contaminants, resulting in lower restriction. During cold temperature warm-up periods, an EaO lube filter allows the oil to easily flow through the filter compared to a typical cellulose filter. Lower restriction decreases engine wear.
More Capacity
A filter’s capacity refers to the amount of contaminants it can hold and still remain effective. AMSOIL EaO Filters have a far greater capacity than competing filter lines. When used in conjunction with AMSOIL synthetic motor oils in normal service, EaO Filters are guaranteed to remain effective for 25,000 miles or one year, whichever comes first.
Superior Construction
AMSOIL Ea Oil Filters are made with premium-grade full synthetic media. The strictly controlled processing of this media ensures accurate filter construction, and is what allows Ea Oil Filters to deliver higher capacity and efficiency along with better durability.
Over the service life of a conventional cellulose filter, hot oil will degrade the resins that bind the media. The Ea Oil Filters’ full synthetic media technology is resin-free. It uses a wire screen backing that is pleated with the media for superior strength.
Ea Oil Filters are constructed with HNBR nitrile gaskets that are fully tested to extreme distances in numerous severe environments. The filters also feature fully tucked seams, a molded element seal, roll-formed threads and a long-lasting premium-grade silicone anti-drain valve.
Applications
AMSOIL Ea Oil Filters provide superior oil filtration for vehicles in the auto/light truck market.
Service Life
AMSOIL Ea Oil Filters are guaranteed for 25,000 miles or one year, whichever comes first, when used in conjunction with AMSOIL Synthetic Motor Oil. AMSOIL recommends changing the oil filter at the time of oil change.
If used in conjunction with AMSOIL Motor Oil that is being changed at intervals less than 25,000 miles, the EaO Filter should be changed at the same time. AMSOIL EaO Filters are not guaranteed for 25,000 miles when used with any oil other than AMSOIL Motor Oil and should be changed according to vehicle OEM recommendations. "
An exploded view of a high quality oil filter -
http://www.amsoil.com/products/oil_a...lter_900px.jpg
Steve
Old May 31, 2007 | 06:55 PM
Jeff92se's Avatar
Red Card Crew
Neither is Mobil 1. Mobil 1 is also a highly refined petroleum oil.,
Mobil 1 is a good oil. Castrol is not a synthetic oil in the traditonal sense of the term, but merely a highly refined petroleum oil, as many, "synthetic", oils today are.
A sythetic oil has vastly greater film strength than a petroleum oil has, so the lightest viscosity possible will provide the best lubrication, protection, horsepower, engine cooling, performance and fuel economy. A true PAO synthetic oil in a 0W-30 viscosity, (like AMSOIL Series 2000 0W-30, or Mobil 1 0W-30 if you want to spend more), is a fine choice.
Steve
Old Jun 2, 2007 | 05:43 PM
Corvettekid's Avatar
So i am about to do an oil change also. Any word on what your final answer was? haha. What oil and filter did you go with?
Old Jun 2, 2007 | 06:04 PM
ebuy929's Avatar
mobile1 5w30 full synthetic]]
mobile1 oil filter
Old Jun 2, 2007 | 06:14 PM
mobile1 oil filter
Cool, thank you
Old Jun 3, 2007 | 12:08 AM
Originally Posted by Corvettekid
Cool, thank you
A decent discount auto parts store oil.
I personally much prefer AMSOIL oil and Ea oil filters for about the same price, but much better perfomance and far less cost.
Steve
Old Jun 3, 2007 | 09:31 PM
NETSHARK's Avatar
Steve
I Live in a Very HOT country in summer we reach About 135 F sometimes we reach about 140 F, and in winter we reach minimum of 48 F but this is only in a cretain hours like from 12 am to 3 am only, the normal time it will stay at around the 50`s F, so please wich one of these oils do you prefer, i was using the Mobil1 Full Synthetic oil 0W-40 (The one on the Right on the picture) since i got my car then i`ve switched to Castrol RS Full Synthetic 10W-60 since the last 3 oil changes, so please can you guide me to the best one for me, what do i know about oil the higher the vilocity is better for the hotter climates, thanks in advance.
P.S: sorry OP for the hijack
Th611
Oct 27, 2015 03:48 PM
flytim3
Sep 5, 2015 01:23 PM
GCoupe35
DFW G35 Owners Club
34
May 23, 2009 02:00 PM
iJeff
Jun 5, 2007 11:10 AM
nikko
Nov 15, 2005 08:42 AM
