Car starts then dies
Old Jun 13, 2007 | 05:52 PM
jim620's Avatar
I have a 2004 Sedan and I just replaced my battery. Now when I start, the engine starts then dies immediately. If I give it a little gas it catches OK and runs. Any ideas?
Old Jun 13, 2007 | 05:55 PM
350.GT's Avatar
Check your intake filter and sensor. Its choking on something.
Old Jun 14, 2007 | 11:21 AM
jim620's Avatar
Where are these located?
Old Jun 14, 2007 | 12:16 PM
maliy06's Avatar
its where the air suction to the engine is. make sure everything is hooked up good and not lose.
Old Jun 14, 2007 | 12:22 PM
ttrank's Avatar
Grocery getter
Re-check the connections on the battery. If the ground is loose it will have a hard time at idle but run off the alternator when it is revved.
Old Jun 14, 2007 | 10:08 PM
jim620's Avatar
It seems to start fine if the engine is cold, ie the car hasn't been run for 4 hours or more but when the engine is hot such as after 15-20 minutes of driving and shutting off the engine and then turning it back on it doesn't seem to catch.
Old Jun 15, 2007 | 02:56 AM
johnsonhuang's Avatar
then its definitley your battery cable. my battery cable was wiggly after i installed a new battery and it would just die at idle for about a week. had to retighten it and it was fine.
Old Jun 17, 2007 | 11:54 PM
jim620's Avatar
Checked and tightened all the battery cables and still happens. Would this problem be covered under the powertrain warranty. My sedan is at 61k just past the basic warranty.
Old Jun 18, 2007 | 04:58 PM
jim620's Avatar
I'm going to try and clean the IACV. Anyone have any pics of where this is located and how I should proceed to remove it? Thanks.
Old Jun 18, 2007 | 05:09 PM
TIRE_SMOKE96's Avatar
I've had this problem before and for me it turned out to be the fuel pump. Your car is acting the same way as one of mine did.
Old Jun 18, 2007 | 08:00 PM
joedaddy1's Avatar
clean your MAF sensor.. it might be dirtayyyy
is ur car stock?
Old Jun 18, 2007 | 09:57 PM
nghiars's Avatar
I know exactly what the problem is.. I had this issue in March... its your throttle body... try cleaning it and if that doesnt work you will have to replace it.. hope you are still under warranty.. its an 04 so if your mileage isnt too high, it should be... i took off my pop charger b4 i brought in my car, left the z tube on and then dealer asked me to bring that in just so they can make sure it wasnt something i did... all in all it was fixed under warranty
Old Jun 18, 2007 | 09:58 PM
nghiars's Avatar
at 61k... you might still be under powertrain warranty.. its motor related so it should be powertrain warranty
Old Jun 18, 2007 | 10:35 PM
jim620's Avatar
Where is the MAF sensor and Throttle body located? I took off the shield today but I don't know what they look like. I also didn't find the IACV.
Old Jun 18, 2007 | 11:47 PM
nghiars's Avatar
MAF sensor is a lil flat like box btwn the air box and the tube.. throttle body is after the intake tube... the metal part connected to it... there should be pictures in the manual or try looking for one online. If you're stock, break it to the dealer.
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
realtalk21
Jul 20, 2015 09:07 AM
