smoking too much after turbo install
hello
is it normal that the car smokes alot after turbo installation?
It smokes so much people stare at me.
Will this go away eventually?
Originally Posted by Mr_pharmD
depends on what kind of color of smoke. If white then u are in trouble. If black then u just running pig rich and a tune should reduce the smoke.
omg, so I 'm in trouble..?
what can be the problems??
I have APS ST kit..
Is it a stock block? I cracked just about every piston and bent almost every rod as well after install of my greddy kit. Basically the oil is just blowing by your pistons and exiting out the exhaust. Or it could be just an oil leak and its burning on the exhaust. Get it checked out and good luck man.
Originally Posted by steve21
ouch! dude that sucks......but stuff happens when u go FI! hope it all works out
APS ST kit comes with an oil control solenoid, but mine didn't and it's on the way from australia.
This might be the problem??
Well, exactly what's going on is that everytime I start the engine and start driving, it smokes crazy. But if I drive it for a while, I don't quite notice smoke.
help me out here.....
that's the problem. the APS ST utilizes a turbo that's positioned lower than the oil pan top itself. so you'll need a scavenging unit to forcefully push the oil back into the oil pan... otherwise, the oil in the turbo will stay at the turbo, coke and cook when the turbo is hot and blow the burning remains and gas away.
seriously, do not drive too hard without the oil scavenging unit.. if i was you, i'd probably source one from jegs before even driving the darn thing.
good luck.
good luck.
I have an 06 coupe with the aps single turbo kit, intake, and exhaust and Im getting smoke from the exhaust but not white smoke its black-ish and it will leave a residue on the back bumper.
any ideas of where to start looking.. or if its just a tune..
anybody know a good place in se PA ?
Where you smoking on WOT or decelerating? What's your Oil Level? If I'm not mistaken APS recommend not to have your Oil on "High" on the dipstik.White smoke is a little scary, are you sure it is not bluish white smoke?
