Pulled ECU code : P0302 | Now what?
Old Apr 23, 2008 | 01:37 PM
Graphite's Avatar
No,i properly replaced all of them with all new iridium plugs and it still shows p0302.
Old Apr 23, 2008 | 01:38 PM
Jeff92se's Avatar
Red Card Crew
Then it's time to consider other things on the list.
Old Apr 23, 2008 | 01:46 PM
Graphite's Avatar
fuel injector maybe? im thinking about taking it to the dealership if i cant find the main cause.
Old Apr 23, 2008 | 05:44 PM
erdog's Avatar
Did you pull out the spark plug for #2 to make sure it is still gapped correctly and maybe even put in a new spark plug in there to see if it is a problem with the spark plug?
Old Apr 23, 2008 | 07:37 PM
Graphite's Avatar
the old plug was still gapped correctly by specs, there was no corrosion, in fact, it still had some life to go for a few thousand miles, so plugs and coils are out of the list for me. its either the injector or the exhaust valve if not i really don't know.
Old Apr 24, 2008 | 11:24 AM
sliderg35's Avatar
I would expect you to get 2 codes if you swapped the wires for the coils. 0302 and 0304 - but I haven't tried it.
Check the connector for #2 (disconnect and reconnect) and if that doesn't fix it, switch the coils from #2 and #4 - then if the code moves to 0304, you know the coil is toast.
Old Apr 24, 2008 | 04:08 PM
erdog's Avatar
Yes you would get two codes if that was the case. He's tried switching the coils but to no avail as per a previous post.
Old Apr 25, 2008 | 09:26 PM
Graphite's Avatar
i had two codes pop up but they were both p0302.
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
Detailed Image
Sep 4, 2015 08:35 AM
