I need more boost!!!
Old Sep 4, 2007 | 08:58 AM
Iceman8's Avatar
Originally Posted by Q45tech
Boost PSI without inside plenum air temperature data [air density] is pretty meaningless since a 100F differential can result in a minimum of 9% and more likely 13% difference in power output.
Exceeding 150F will cause real problems with pump gasoline.
Im not sure what your talking about here unless it was in reference to another posters quote.
Old Sep 4, 2007 | 02:23 PM
Dr_jitsu's Avatar
I assume that you ar reunning the EU eng. managment, yes?
Get a V-pro and bigger tires (305 on the rears) and you should have no problem running a reliable 500rwhp. Then you can start to play w/ the big boys.
Old Sep 4, 2007 | 03:39 PM
Iceman8's Avatar
Oops, Ive got a utec...man I think I spent a few hours with my back arched over the doors sill mounting that Facking thing. I think if I go bigger with tires my max will be 285's sticking out a little bit. The local cowboys around here are sticklers, they love giving window tint tickets. 500rwhp would be dope...I think I read that my internals were rated to about 14lbs or 450hp(eagle rods & Arias pistons-no extreme duty) is that right?
Old Sep 4, 2007 | 09:18 PM
Dr_jitsu's Avatar
UTEC is a solid system. Just get her tuned properly (very important) and get the largest tires you can fit (although you will spin 285's) and enjoy her.
g.spot
May 9, 2016 10:54 PM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
ncg35guy
Sep 24, 2015 04:53 PM
