Couple oil questions...
Sep 17, 2007 | 12:42 PM
  #46
I'm confused. So you are using Motul based on that particular test? Or because it's better suited for your particular application? I don't see the two being one in the same.
Quote: Redlude97.....
About a year ago...there was a company at the race track giving a demonstration about what happens to oil at a certain temp. They would put the oil in a frying pan and heat it to around 200 degrees...then 300 and so on.
Motul came out the best and this was not even their company...
They were just showing us what we needed to use in a certain application.
Reply 0
Sep 17, 2007 | 04:45 PM
  #47
Quote: Why would he need a cooler in the 1st place?
commen sense
Reply 0
Sep 17, 2007 | 04:53 PM
  #48
Quote: commen sense
What if the following?
1) Cooler oil doesn't address his high rpm metal on metal prevention concerns?
2) Or the oil isn't getting to the temp requiring a cooler?
Reply 0
Sep 17, 2007 | 04:58 PM
  #49
Quote: commen sense
But you have been insisting that every oil is the same and should be sufficient to protect our motor. So why do you need a cooler unless you live in a constant 100deg temp or FI'ed?
FYI, not oil are the same and there are off-the-shelf oil that can withstand track and there are also off-the-shelf oil that can break down after a few hundred miles of track driving.
Reply 0
Sep 17, 2007 | 05:14 PM
  #50
Quote: But you have been insisting that every oil is the same and should be sufficient to protect our motor. So why do you need a cooler unless you live in a constant 100deg temp or FI'ed?
Is there anthing you dont know you have a answer for evrything
Reply 0
Sep 17, 2007 | 05:20 PM
  #51
Quote: Is there anthing you dont know you have a answer for evrything
But you act like you know Chit
Reply 0
Sep 17, 2007 | 05:26 PM
  #52
Quote: But you act like you know Chit
lmao ok wwwaaassssooooo boy
Reply 0
Sep 17, 2007 | 05:27 PM
  #53
Forget it. I now realize who I was asking.
Reply 0
Sep 17, 2007 | 07:16 PM
  #54
Quote: I'm confused. So you are using Motul based on that particular test? Or because it's better suited for your particular application? I don't see the two being one in the same.
I have been road racing for over 14 years....so I did not need that test to help me pick a brand of oil. the test only showed what happened to different brands of oil at curtain temps. Like I said before, Motul was the only brand that did not break down at high heat.
Nismo G does not need to use the same racing oil as me...he can use a brand a few steps down that can help with heat transfer and lubricating.
I have to use oil that can stand up to excessive temps because my car operates close to redline for many laps....remember....this car is not use for drag racing.
Reply 0
Sep 17, 2007 | 07:22 PM
  #55
All I'm asking is HEAT the main enemy here? Or is it a film strength issue? Or has oil analysis shown that your oil is having heat related stress?
Quote: I have been road racing for over 14 years....so I did not need that test to help me pick a brand of oil. the test only showed what happened to different brands of oil at curtain temps. Like I said before, Motul was the only brand that did not break down at high heat.
Reply 0
Sep 18, 2007 | 08:24 AM
  #56
Quote: All I'm asking is HEAT the main enemy here? Or is it a film strength issue? Or has oil analysis shown that your oil is having heat related stress?
Heat and Viscosity are my main concern
Reply 0
Sep 18, 2007 | 09:26 AM
  #57
Quote: Heat and Viscosity are my main concern
I curious to know how you came to this conclusion.
Reply 0
Sep 18, 2007 | 12:11 PM
  #58
Nismo so what oil are you going with?
Reply 0
Sep 18, 2007 | 04:09 PM
  #59
Quote: Nismo so what oil are you going with?
Motul 0w-40
-Sean
Reply 0
Sep 18, 2007 | 04:10 PM
  #60
Waste of $ but it's good oil I suppose.
Quote: Motul 0w-40
-Sean
Reply 0
