water temp guage install
Old Sep 26, 2007 | 06:05 PM
bluestacy04's Avatar
Did you guys put the adapter on the top hose or the hose that runs down to the bottom of the radiator? The install stuff I see says to use the top hose, but our top hose is so small.
Thanks in Advance
Old Sep 26, 2007 | 06:59 PM
sliderg35's Avatar
If you use the bottom hose, you'll get the temperature of the water in the radiator - not the engine. You need to find a place near the top return hose.
Old Sep 26, 2007 | 07:25 PM
so I should use the top hose then for a better reading...
Old Sep 27, 2007 | 03:03 PM
Where did everyone else put the adapter? The top hose is not an option with the way the bends are.
Old Sep 29, 2007 | 02:46 PM
anyone???
I think I can cut the top hose to were it will work, but if I'm wrong its and expensive mess up on my samco's.
Someone please chime in.
Kng0fHrts
Sep 15, 2015 05:40 PM
jcardodeucedos
Aug 27, 2015 06:28 PM
joedaddy1
Jul 28, 2015 02:58 PM
