Which oil to use after 65k miles?
Old Sep 28, 2007 | 06:19 PM
DG35Cpe's Avatar
I have had the dealer service the car but i am out of those coupons i had got when i got the car. I think they were using regular castrol, so what should i start using from here on out?
Old Sep 28, 2007 | 07:54 PM
Still2Slow's Avatar
Depends..... Pennzoil Platnium 10W-30 is ok or Mobile1 0W-40. Change around 3-4K and you should be ok.
Old Sep 28, 2007 | 07:59 PM
DG35Cpe's Avatar
thanks
Old Oct 1, 2007 | 01:07 PM
Swivel's Avatar
Moderator
Amsoil 5W30 or other full synthetic.
Old Oct 1, 2007 | 01:08 PM
Jeff92se's Avatar
Red Card Crew
Or use what you have been using.
Old Oct 2, 2007 | 08:00 AM
Q45tech's Avatar
The only scientific way is to measure bearing and ring clearances and hot idle oil pressure vs brand new and in 30k increments.
Generally Nissan don't fully wear until 150k+ and by 300k time to swap engines.
Old Oct 4, 2007 | 03:58 PM
DG35Cpe's Avatar
so basically it doesnt matter if i go fully synthetic or not? Just as long as i stay consistent from here on out?
Old Oct 5, 2007 | 06:55 AM
g35rcr's Avatar
why would you tell him to run either a 10w or a 0w...just run 5w30 and you will be fine...
vmcarbuyer
Oct 12, 2019 12:42 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
ClwMike
Jul 23, 2015 12:55 PM
