Help with installing grounding kit.
Old Feb 14, 2004 | 03:06 PM
RashMan1450's Avatar
Man i did a search, i even looked at the thread the grounding kits. I came up blank. I know there is somewhere that there are instruction on how to install these. But see with me i need the pictures.
I got www.z-xtreme.com's kit but his directions are not that clear for me. I need pics to go along with it.
If somebody can help me out that would be awesome thanks
2004 Diamond Graphite G35 Coupe 6MT, Premium Package, Aero Package, DVD Nav
Old Feb 15, 2004 | 12:22 PM
SFLG35's Avatar
FGC President
Re: Help with installing grounding kit.
sent you an email with all the pictures and instructions i used
they will get you up to 12 wires if you want
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights
Old Feb 15, 2004 | 12:28 PM
SFLG35's Avatar
FGC President
the email i sent came back say it wasnt an email address. i used the one in your profile. let me know what a good one is and ill send the file to you again
Daniel
Old Feb 15, 2004 | 08:14 PM
GLuvin's Avatar
Take look at this pic. "Gordgee" posted a picture of the install along with each of the wires numbered. Wires 3 and 4 are swapped in this pic vs Z-Xtremes instructions. I just did Z-xtremes 7 wire install yesterday, PM if you have any questions, I can walk you through it. One note, Z's 6th wire goes back by the plenum on the same bolt as the 5th wire rather than up front with the other 3 wires.
https://g35driver.com/forums/showthr...collapsed&sb=5
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
Old Feb 15, 2004 | 08:59 PM
GLuvin's Avatar
Here is marked up picture showing the ground point for Z-xtreme's 6th wire. When I get my camera back I will show the whole thing.
Old Feb 15, 2004 | 09:02 PM
GLuvin's Avatar
<font color=red>The above picture is Copyright © 2003/04 GroundingGear Ltd. Unauthorized use or reproduction is prohibited. Permission is given for G35driver forum members to link to the existing picture ONLY. Other uses or reproduction is allowed only with written permission of GroundingGear Ltd.</font color=red>
sorry, pic too big, try again.
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI<P ID="edit"><FONT class="small"><EM>Edited by gordgee on 02/16/04 09:14 AM.</EM></FONT></P>
Old Feb 16, 2004 | 02:50 AM
Ohh man that helps out so i did it right then. Another question our #3 and 4 is flipped or no. If i flip them the wires will be too short.
Old Feb 16, 2004 | 12:05 PM
Gordgee's Avatar
Administrator
Z-Xtreme's wires may be numbered a bit differently than GroundingGear™. As long as the wires can be run to the appropriate spots, just follow his instructions, and use my posted pic.
BTW, you guys know that GroundingGear™ is about the same price on this forum (only) as Z-Xtreme's right? Only for G35/350zs though as the authorized dealers don't want me to do direct sales of GroundingGear™ Universal Series kits, nor Custom Series for other vehicles.
<font color=blue>GroundingGear™ Equipped </font color=blue>
Old Feb 16, 2004 | 01:00 PM
GLuvin's Avatar
Actually, I was referencing an older pic. 3 and 4 are the same in Grounding Gear's pic above and Z-Xtreme's instructions.
Sorry for the confusion.
Old Feb 16, 2004 | 01:31 PM
fluffydot's Avatar
I feel you rashman.... that;s the same reason my grounding kit has been sitting in my room for 2 months now..
thanks for the pic. but where does the other end of wire #2 go?
also, if I only got the 5 wire kit (for 6MT), do I just install #1-5?
Old Feb 16, 2004 | 01:35 PM
GLuvin's Avatar
Wire 2 goes to a grounding bolt on the passeger wheel well. If you remove the hood sensor (2 10 MM bolts) you will see it about 2 inches below.
Wire 7 is the only wire not needed on the 6 MT. You should install all 5 wires.
Old Feb 16, 2004 | 06:45 PM
i didnt even need to remove the hood senor to get to that spot. I think i should make a revised version of the picture.
This will help out alot of people.
Old Feb 16, 2004 | 10:07 PM
cloudkid's Avatar
Can someone post a link of where to buy the kit? The easier the better! Looks like most go with GroundingGear? Would be greatly appreciated!
<P ID="edit"><FONT class="small"><EM>Edited by cloudkid on 02/16/04 07:08 PM.</EM></FONT></P>
Old Feb 17, 2004 | 12:02 AM
Gordgee's Avatar
Administrator
For more info and links to several sources:
Hyper-Ground FAQ Thread
zoop425
Mar 29, 2016 05:51 PM
willdogs
Dec 8, 2015 11:32 AM
RA081024
Aug 18, 2015 07:03 AM
Ninjay16
Jul 20, 2015 01:21 AM
