VQ35DET
Old 02-19-2004 | 08:54 AM
zippiziggi77's Avatar
VQ35DET
is there any source that I can get this engine imported from japan? I wanna do engine swap so badly
Old 02-19-2004 | 09:44 AM
AirWarrior's Avatar
Re: VQ35DET
what does the VQ35DE"T" have that ours doesn't? (other than the T)... does it stand for Turbo?
Old 02-19-2004 | 11:04 AM
ImportFreak's Avatar
Re: VQ35DET
t stands for turbo
2003.5 II G35 II Coupe II 6MT II BS II Prem. II
Old 02-19-2004 | 04:25 PM
SkylineGT's Avatar
Re: VQ35DET
Does it even exist?! The VQ35DE is a V6 engine...where will this one turbo be placed? Under the car? LOL.
Old 02-19-2004 | 10:20 PM
nuttyprof's Avatar
Re: VQ35DET
hmm, cool, turbo. i want to see that VQ32DETT already. id say wait for that to swap.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old 02-20-2004 | 06:10 AM
808350GT's Avatar
Re: VQ35DET
i'm not sure if they make a VQ35DET but they make a VQ25DET that is in the Stagea
http://www.nissan.co.jp/STAGEA/M35/0...EUP/index.html
Old 04-19-2007 | 02:22 PM
SkyBlueG35's Avatar
why would you use a single turbo in a V-type engine
Old 04-19-2007 | 02:24 PM
izmir41500's Avatar
G35driver Addict
why not?
Jeff92se's Avatar
Red Card Crew
I've taken a look at the VQ35DET manifolds. From what I see, the USDM steering linkage most likely gets in the way. Also the Gloria/Cedric seem to have more room down where this turbo is placed. Also in Japan, the steering is on the other side, providing more room for the turbo
Old 04-19-2007 | 02:33 PM
SkyBlueG35's Avatar
a single turbo would be a waste of money its only like 1200 more to get a twin setup
Old 04-19-2007 | 02:35 PM
Jeff92se's Avatar
Red Card Crew
Why are twin necessarily "better" than a single?
Old 04-19-2007 | 02:41 PM
SkyBlueG35's Avatar
it will provide more power at a slighlty higher RPM. for example a single turbo car running lets say 200hp more than stock would lose in a 1/4 mile to a twin turbo car running 200hp more than stock because the power is spread more evenly through the rev range instead of the surge of one turbo
Old 04-19-2007 | 02:46 PM
Jeff92se's Avatar
Red Card Crew
You can't really say that. As you haven't stated the turbos used in each application. Use too big of turbos on a TT application and you will have lag. As only 3 cylinders are powering each turbo.
You can have a small single (powered by all 6 cylinders) and have GREAT throttle response and midrange punch. Or you can put a med/big turbo and get high end power w/ some low end lag. Or you spend mega dollars and use a ball bearing center sectioned single turbo and get it all. Low/mid/high w/ little lag.
What you say below is true to a point. But if the 1/4 is the only consideration then you also have to account for tranny. Use an auto tranny for the quarter and they can brake boost and launch while already in + psi. aka no lag
Old 04-19-2007 | 02:49 PM
trey.hutcheson's Avatar
You're arguing in a thread that was dead for over three years? I'm sure your intended audience isn't around anymore.
