PLEASE HELP!!! Can't bolt engine/tranny together! :(
Old Nov 21, 2007 | 12:58 AM
dualGz's Avatar
And I'm having some problems. There is a solid 1/8" gap between the tranny and the engine, and the bolts feel pretty tight. It's all aluminum, so I'd rather not torque stuff down, and go crazy and strip stuff out.
I've backed the tranny off once so far, and checked the torque convertor to see if it's seated right. Everything seems good. I can't push it back onto the tranny any farther. I got two "clicks" out of it when I was seating it. The first click when I put it on, and the second when I turned the TC around a little to get it farther on the input shaft. The engine and tranny came together from the factory, so it "should" be going together fine.
What can I do to get these two together in harmony? I have to work tomorrow, but if I can get some responses here, I can probably try a few things before work tomorrow.
My opinion is that the two should slip right together, and bolt up without too much trouble. Can some one give me some insight? What am I doing wrong? PLEASE help me! As much fun as it is to take the GSXR to work everyday, I REALLY like the cushy comfy G35.
Old Nov 21, 2007 | 01:09 AM
SILVERSURFERG35's Avatar
What do you have the tranny resting on ? If you have the tranny on a jack you might have to jack it up a little to make sure it is going in strait ! You can also try twisting the tranny slightly back and forth for it to get a better fit . There sould be no space as you know between the tranny and the motor .
Old Nov 21, 2007 | 01:54 AM
jjyellow's Avatar
make sure torque converter is all the way in. Turn it and push it in at the same time.
Old Nov 21, 2007 | 03:55 AM
Scrooge's Avatar
Make you filled you TC with one quart of nissan fluid and then put it on and twisting it intil it's flush with the case. a jack stand a jack will help you keep your tranny straight with the engine. Since you might have the car rinse my up in the front
Old Nov 21, 2007 | 08:46 AM
dualGz's Avatar
The TC was well flush with the case. If not farther in. How many "clicks" does it take to seat the TC on the Infiniti transmission?
Old Nov 21, 2007 | 07:37 PM
jjyellow's Avatar
I belive its 3 clicks and it should lay in the housing and not be flush with it. You can tell when its fully in when you turn the converter and feel some resistance to you turnign the converter while in the tranny
Old Nov 21, 2007 | 08:36 PM
Audible Mayhem's Avatar
keep turning it back and forth till it goes all the way back in .
make sure to lube it all up too, all the dowel pins and everything that contacts metal to metal to make sure it slides in easy..
Old Nov 22, 2007 | 02:28 AM
dualGz's Avatar
Yup... Three clicks it was. Unfortunately, it wasn't on the new transmission. I put the old TC back on the old trans, and bolted it up. A little bummed about it, but eh, not a huge deal I guess. I'll pull apart the new trans and see what kind of damage I did.
On the new TC and tranny, the TC won't go past the first 2 clicks.
Old Nov 22, 2007 | 02:35 AM
BayAreaRefuGz's Avatar
i fly low
turn the torque converter in the position that the flexplate is (since it's easier to turn the TC than the flexplate).
when installing, make sure the DOWELS are in place. dowels are the most common reason for it to leave a gap
Old Nov 22, 2007 | 02:38 AM
dualGz's Avatar
Yeah, it's in now. TC wasn't seated fully from the start. Now on the new trans, it doesn't want to seat at all. I sure hope the new one will be okay!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
doakley92
Sep 25, 2015 12:58 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
