2J Swapped 350Z.....
Old Dec 17, 2007 | 05:53 PM
617G's Avatar
CFW (Carbon Fiber Whore)
Originally Posted by Jeff92se
Because I don't think an iron blocked inline 6 is lighter than an aluminum block V6. If it's replacing a TT v6, it's replacing an already front heavy setup (by their logic) and adding more weight to that.
You have to remember, the VQ35 is light. it's lighter than the VQ30 it replaced and that was 100lbs lighter than the VE30DE iron block V6 it replaced.
I see what you're saying now....well, although it will be heavier than STOCK, it's lighter than a VQ with TT's which don't seem to have an issue so I think they'll be alright
Old Dec 17, 2007 | 05:55 PM
Jeff92se's Avatar
Red Card Crew
Well the thing is you don't have to "build" the 2jz at all. Unless you are going over some insane hp number. ie... 700hp or so.
How much power below 6k rpm would a 700-800hp VQ35 have? Maybe a bit more because of the .5 liter more in cubic inches but probably not much more.
Originally Posted by 617G
It's hard to say it's superior because you're not really comparing apples to apples...in terms of boost, yes, but only because it was overbuilt like you said. But, I would rather build my VQ and put a 2jz in it
I was also refering to the high whp ST supras that had no power below 6k
Old Dec 17, 2007 | 06:00 PM
617G's Avatar
I understand, but what I'm saying is the supra guys think the VQ can't make good power and the shop that's doing the swap is playing it up saying that the only real way to make power in a 350z is to put a 2jz in it, which isn't the case anymore.
brianyun's Avatar
you want power?
screw the vq,
screw the rb,
screw the 2jz
get a viper
Old Dec 17, 2007 | 06:02 PM
617G's Avatar
Originally Posted by brianyun
you want power?
screw the vq,
screw the rb,
screw the 2jz
get a viper
why not a c6z06? you're missing the point
brianyun's Avatar
+1 +1
yeah the VQ is gonna get there...the supra has had 15 years to build 1000+hp engines.... we'll get there...wait and see
Old Dec 17, 2007 | 06:03 PM
brianyun's Avatar
because those are known to break down after you drive them off the lot.
and whens the last time you ahve seen a 1800hp one of those?
Old Dec 17, 2007 | 06:05 PM
617G's Avatar
+1 +1
It's only been 5 and we've already got a couple
617G's Avatar
Old Dec 17, 2007 | 06:07 PM
O HELLA OEM's Avatar
this thread is fun..
Old Dec 17, 2007 | 06:10 PM
Jeff92se's Avatar
Red Card Crew
1800hp supra or this? http://videos.streetfire.net/video/00f3255f-85a0-44d7-9c0f-983c00042243.htm
I wonder which one would be faster?
Old Dec 17, 2007 | 06:14 PM
Jeff92se's Avatar
Red Card Crew
Understood. And I'm not trying to play down the VQ either. I note you're TT so, you have more into this than my meager engine!
Old Dec 17, 2007 | 06:15 PM
brianyun's Avatar
Old Dec 17, 2007 | 06:16 PM
brianyun's Avatar
yeah but it takes a hell of alot more money to get supra kind of power
  #30
Jeff92se's Avatar
Red Card Crew
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/lm5RkeuKC1Q&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/lm5RkeuKC1Q&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
