UR Pulley worth it??
Old Mar 4, 2004 | 04:25 PM
al503's Avatar
Re: UR Pulley worth it??
you got the correct belts. I'm just wondering if the belt tensioners were tightened adequately or if some grease got on the belts themselves. Both will cause the squeeks.
Old Mar 4, 2004 | 07:28 PM
Coz@Czp's Avatar
Exactly, if the belts are on properly, and if pulley is clean, you wil not have any squeaking.
Coz
www.czp.us
Old Mar 4, 2004 | 10:07 PM
protocav's Avatar
i got mine from concept Z performance. excellent price, quick shipping...thanks!
the install was cake. the gains you can feel. my average 0-60 times with the RT cats and the pulley went down 2 tenths of a second (for any that are concerned with that). my belts didn't sqeak on startup, and have been fine for two weeks. i made them pretty tight. i did get one very tiny sqeak on startup the other morning, and i checked them immediately. they felt a tiny bit loose, so i tightened them. this is a great mod, and very easy.
get a 2' breaker bar, put the car in 6th, and have someone stand on the brakes...you will be surprised how easily the bolt comes off.
Chad
Old Mar 4, 2004 | 11:00 PM
zippiziggi77's Avatar
Do i have to take my radiator out in order to fit air gun?
How did u guys install it?
Old Mar 5, 2004 | 10:51 AM
n1cK's Avatar
G35 6MT
well, though there aren't any problems yet, i've seen and heard what lightened pulleys can do. the problem, as all of you already know, is in the harmonic damper and the balancing of the pulley itself. if these aren't made correctly or if the pulley isn't balanced, then it could shake everything off the block, literally! i've always been reluctant to get this mod because of the risk/gain factor. there just isn't enough gain to justify the risk. that's jus' my $0.02.
n1cK
jUs' bE [img]/w3timages/icons/cool.gif[/img]
Old Mar 5, 2004 | 12:17 PM
ychoy's Avatar
Do you know if the crank pulley have any problem going into a 5AT? I'm looking into getting a used one, but I have not heard of anybody did it with an automatic. Thanks
Old Mar 5, 2004 | 01:51 PM
al503's Avatar
I just talked with someone at PerformanceNissan and they said that it would work in the AT. You will need a special tool however to take the stock pulley out. I'll try to find out more because I just ordered one for my bud's AT coupe. Anyone know specifically, what this 'special tool' is?
Old Mar 5, 2004 | 02:45 PM
klg35's Avatar
is tightening that belt tensioner difficult? i can move the belts almost an inch either way, so that seems like the cause of my squeak..........just in case, what's the best way to clean belts, warm water? excuse me for these questions, not too mechanically inclined. i'm the "if-it's-on-a-g35 sedan-and-it-works-with-no-problems,i'm-in" type of guy.
04 Black Sedan 6mt / front blinker mod, z tube+k&n panel filter / 18" r/h c2s w/khumos 235/40zr18 / pre-muffler, what pre-muffler?
Less is more, unless your modding......
Old Mar 5, 2004 | 03:55 PM
ychoy's Avatar
how much you think it will cost to have the dealer to do the installation? I think I might be better off have the dealer install the pulley. I can simple stuff like exhaust, intake, and plenums, but I don't think I'll be able to do that, don't want to break anything.
Old Mar 5, 2004 | 04:04 PM
al503's Avatar
most of the replies on my350z have been around ~$100 for the pulley install.
klg, I'm not sure about how much play there should be. All I can say is that you have to try to get the belts as tight as possible to avoid the squeeking.
Old Mar 9, 2004 | 11:34 AM
milesh11's Avatar
Does anyone ave the UR pulley (crank only or set) in conjunction with aftermarket stero equipment? Any adverse effects / problems? Someone previously suggested in another post that the underdrive may prevent the alternator from providing enough juice for after market stero compnents. I have 2 amps, and was wondering if this is a mod I should avoid for that reason. Thanks for any help.
03.5S DP / Prem / Sport / NAV
18" Coupe Rims w/ S-03 245/45/18
Eibach Pro Kit
Injen CAI
Z-Xtreme Grounding Kit
Upgraded sound (Infinity / MTX / Alpine)
Crawford Plenum (next)
Old Mar 9, 2004 | 12:43 PM
GeeMan's Avatar
You should be cool on the stereo. It's not an underdrive pulley, just a lighter one.
03.5 5AT-S (Black-Willow-Premium-Sport-Aero-GroundingGear™-Silverstars-PIAA-PopCharger-Z Tube-Tint)
Old Mar 9, 2004 | 12:46 PM
al503's Avatar
wow. that's a great question. I will have 2 amps in my system as soon as I have my enclosure built. I never thought about this. I don't know how much smaller the crank pulley is compared to stock but for the sake of argument, lets say the stock system puts out 100 amps at 2000 rpms. If the UR pulley was 20% smaller, I would guess that you would have to rev at 2400 rpms to get 100 amps.
Any thoughts?
Old Mar 9, 2004 | 12:48 PM
al503's Avatar
hey geeman. It is actually a little smaller. There is a comparison pic on my350z. I would guess that it's about 20% smaller.
here's a link to a pic: http://www.my350z.com/forum/showthre...nk+pulley+pics
<P ID="edit"><FONT class="small"><EM>Edited by al503 on 03/09/04 10:02 AM.</EM></FONT></P>
Old Mar 9, 2004 | 03:00 PM
  #30
GeeMan's Avatar
Damn, that's my first mistake this year. My apologies, I was repeating what I had read elsewhere. No substitute for actually having it in your hands.
