Oil Light Question
You have to see how low you are first and add .You may have had only like one or two quarts in there before you added those two quarts . After that check every couple of days to see if it is really bad or just a little oil burning . The harder you drive it the more you will burn so remember that . I had to learn the hard way and had my car knocking and only had one quart in there . 5 quarts is full !!!
