Is bmw 5w-30 same as the Castrol 5w-30?
Old Jan 12, 2008 | 01:45 PM
Klubbheads's Avatar
I have 3 quarts of bmw 5w-30 sitting in my garage for a year already. I wanted to know if i can use them with castrol 5w-30 oil with my upcoming oilchange?
Old Jan 13, 2008 | 04:07 AM
Klubbheads's Avatar
thanks for the help.
Old Jan 13, 2008 | 04:11 AM
Xblackg35X's Avatar
i honestly wouldnt do it. some oils burn hotter than others and can mess up the seals in your engine. thats why your suppose to use the same oil everytime you change you oil
Old Jan 13, 2008 | 06:15 PM
EuG35's Avatar
First of all, I'm sure you can find that answer on the internet with something called the(not sure why I have to tell someone with over 4k posts this):
To answer your title question, NO, BMW 5w-30 is not the same thing as Castrol tw-30 Syntec.
AFAIK:
The BMW 5w30 was made specifically FOR BMW, especially for the e39 M5 and e52 Z8, which had an excessive oil consumption problem similar to ours due to the way the piston rings were designed. The BMW 5w30 also has a slightly different viscosity (at OPERATING temps, not 100 degrees) than the regular US Castrol 5w30 even though they both have the same rating of 5w30. Not to mention the Syntec is 5w30 SAE rated while the BMW oil is 5w30 ACEA rated(if I remember correctly) so the BMW oil is likely going to be more viscuous, like a 5w40. If you put that oil in your car one time you will not see any noticeable difference, but I still wouldn't recommend it. Why the hell are you putting BMW oil in your Infiniti? Just get some Mobil 1. Some people are just stupid.
Old Jan 13, 2008 | 07:42 PM
Klubbheads's Avatar
AFAIK:
If u enhance ur reading comprehension skills, u will probably figure out why the hell i am putting BMW oil into infiniti. Now ur more than welcome to GTFO from this thread.
Old Jan 14, 2008 | 10:33 PM
EuG35's Avatar
HAHAHA OWNED. And since you like pictures so much
KruZZe
Feb 27, 2023 05:04 PM
mbe32
Nov 13, 2015 11:09 PM
MrIP35
Oct 25, 2015 11:13 PM
Learned Hand
Oct 1, 2015 09:02 AM
CV35Driver
Sep 15, 2015 05:09 PM
