06 sedan missing throughout the rpm range suggestions?
Jan 16, 2008 | 06:32 PM
My 06 sedan is missing through the rpm range above idle and the VDC and Slip lights come on atfer reving the engine and stay on i replaced the crank sensor and it changed nothing what is worng
Any suggestions or expierenaces
Reply 0
Jan 16, 2008 | 06:37 PM
You mean your entire sedan is missing throughout the whole rpm range?
How is that possible???
Reply 0
Jan 16, 2008 | 06:48 PM
me no get it.
Reply 0
Jan 16, 2008 | 09:04 PM
it happens
Reply 0
Jan 16, 2008 | 09:13 PM
Quote: My 06 sedan is missing through the rpm range above idle and the VDC and Slip lights come on atfer reving the engine and stay on i replaced the crank sensor and it changed nothing what is worng
when you say missing, do you mean misfiring? is your cel on and is it blinking? also what lead you to replace the crank sensor?
Reply 0
Jan 17, 2008 | 12:33 AM
+1?
What about the fuel pump, spark plugs, bad gas?
Reply 0
Jan 17, 2008 | 01:57 AM
wow something is wrong... what gas are you running?
Reply 0
Jan 17, 2008 | 06:09 AM
After reading the first post more than just several times, I think I understand what he's saying... His car is not catching traction. Is this only in first gear? Or all gears? Or do you have an auto?
Reply 0
Jan 17, 2008 | 03:06 PM
Sounds more like it's running on 5cyl to me.
Can you give us some more detail on the symptoms.
Reply 0
Jan 17, 2008 | 05:29 PM
Quote: Can you give us some more detail on the symptoms.
+1
"My 06 sedan is missing through the rpm range above idle" doesn't tell us too much
Reply 0
Jan 17, 2008 | 07:19 PM
Quote: it happens
Reply 0
