Disconnect battery for ecu reset??
Old Mar 14, 2004 | 02:50 AM
NYG35shark's Avatar
I was wondering if anyone knows if you disconnect the battery does it reset the ECU...I had a problem with my 99 vette once where the computer tripped out and by disconnecting the battery it reset the system so what i want to know is if you make mods on your car an disconnect the battery will the ecu run according the to level of the mods??? I don tknow if this is a dumb question but i had to ask>>
Old Mar 14, 2004 | 08:38 AM
GLuvin's Avatar
Re: Disconnect battery for ecu reset??
Look at the top of the mod forum.
https://g35driver.com/forums/showfla...sed&sb=5&part=
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
Old Mar 14, 2004 | 01:45 PM
Msedanman's Avatar
O.F. Administrator
There is a thread in our FAQ/DIY forum devoted entirely to this subject.
LOOK HERE, and good luck.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Mar 14, 2004 | 04:23 PM
DHCrocks's Avatar
you can just remove the ECU fuses in the engine compartment by the battery (15A) and the drivers side kick panel fuse block (10A). wait 3 min, crank the engine, wait 3 min, replace fuse and your're good to go.
Old Mar 15, 2004 | 08:46 AM
malx's Avatar
There is a was to reset the ECU by disconnecting the battery but you will lose things like your radio stations programed, if you care. Unless you do it the way described above hitting the gas brake, etc.
Thanks - Joey Avino
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
happydays888888
Oct 6, 2015 06:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
