Help on deciding with Plenum & Spacer?
Old Feb 9, 2008 | 03:55 PM
citymunky's Avatar
Originally Posted by ckg35
I hadn't heard there was a plenum or spacer upgrade yet for the '07 G35/G37. Try Emailing Motordyne to see if they've been doing any testing to see if a spacer is actually going to produce gains.
There is no 2007 G37 coupe
Old Feb 9, 2008 | 05:45 PM
Still2Slow's Avatar
OEM polished plenum with either Motordyne 5/16" or 1/2".
Old Feb 10, 2008 | 06:10 PM
ckg35's Avatar
Thanks for being so pedantic! I think most know that the G37 isn't a 2007 model, so I never bothered clarifying.
Old Feb 11, 2008 | 01:42 AM
kbmoney's Avatar
ive purchase and install a motordyne 1/2" plenum spacer to my 2004 g35 and i wanted to if i was to use the 5/16" instead. What is better
Old Feb 11, 2008 | 02:52 AM
Deepdiver's Avatar
stick with the 5/16; you will have performance increases over a wider range of the power band.
Old Feb 11, 2008 | 03:25 AM
JJJAAASSSOOONNN's Avatar
motordyne, no ifs ands or buts
Old Feb 11, 2008 | 05:27 PM
AGThing1227's Avatar
Let me add to this.
If you have a 2005-07 6MT ("RevUp" Motor) then get the MREV2. If you have a 2005-07 Automatic, ill stick with the 5/16" spacer.
Also you the Cosworth is nice, but i would only get it if I was going F.I. (Turbo or Supercharger). The HP/TQ gains for N/A are similar to the 5/16" and
MREV2.
Yea, I heard the Cosworth are supposed to be pretty damn good with FI but the backorder SUCKS(so does the price but you can't complain)!
Old Feb 11, 2008 | 06:43 PM
OCG35's Avatar
It’s absolutely not worth dumping the 1/2" and getting 5/16" - It is HIGHLY doubtful that you would feel the difference. Since you already have the 1/2" stick with it. I run 1/2" and have zero reason or need to get a 5/16" instead...
Old Feb 23, 2008 | 12:59 PM
kbmoney's Avatar
ight.
Old Feb 23, 2008 | 07:17 PM
JesusGTR's Avatar
question with the revup motor can we use the MREV2 with a 1/2 spacer?
Old Feb 23, 2008 | 07:24 PM
Texasscout's Avatar
Yes you can.
Old Feb 23, 2008 | 07:46 PM
JesusGTR's Avatar
Is there a better upper plenum such as the APS tall boy or something that might work better with the MREV2?
Old Feb 23, 2008 | 08:49 PM
SxExCx's Avatar
The APS will work the same as an OEM with a spacer
Old Feb 23, 2008 | 11:10 PM
1g35fan's Avatar
Motordyne FTW! Ease of install with proven results.
Old Feb 24, 2008 | 12:11 AM
  #30
citymunky's Avatar
I'm just making sure everybody knows
