am confused guys .. need help
Old Jan 29, 2008 | 12:52 PM
kuwait_G35's Avatar
hi guys ..
am confused in two things ..
, i have a 2003 auto G35 coupe..
my engine blew...
the reason was one of the Connecting Rods was broken !!!!!
when i go to the mechanic guy , he told me "i must change the rod "
and everything will be fine and this will cost me maybe 1000$
but, am planing to buy a new preformance pistons , preformance rods !!!!
like :
1- Brian Crower Connecting Rods
2- CP Forged Stock Bore Pistons Oversize +5mm (96mm) Bore - 11.0 CR
.. and this will cost me maybe mm $2800
so what do you think ... for daily use drive, by the way i do not want te get turbo or supercharge ,, just wanna some HP in NA ...
and maybe nitrous
so what do you think .. ???
Old Jan 29, 2008 | 12:59 PM
g35rcr's Avatar
doesnt hurt to have stronger internals, but if you are not going fi its not necessary
Old Jan 29, 2008 | 01:03 PM
kuwait_G35's Avatar
mmm how many hp i will get from those preformance pistons and rods ???
Old Jan 29, 2008 | 01:04 PM
617G's Avatar
CFW (Carbon Fiber Whore)
zero
Old Jan 29, 2008 | 01:10 PM
kuwait_G35's Avatar
Originally Posted by 617G
zero
sure ????
Old Jan 29, 2008 | 01:14 PM
Deezflip's Avatar
Yes zero, they're only installed to handle forced induction/combustion
Old Jan 29, 2008 | 01:34 PM
kuwait_G35's Avatar
mmmm alot of guys told me that i will feel a big differnce when i buy preformance parts ... !!
Old Jan 29, 2008 | 01:42 PM
617G's Avatar
unless the piston is higher compression, you will not gain anything
Old Jan 29, 2008 | 01:47 PM
kuwait_G35's Avatar
the piston which i will buy it is
Old Jan 29, 2008 | 11:58 PM
kuwait_G35's Avatar
so what do you think ?
Old Jan 30, 2008 | 12:42 AM
Xblackg35X's Avatar
wouldnt do to much nitrous on high compresion engine man
Old Jan 30, 2008 | 12:43 AM
Xblackg35X's Avatar
and are you going dry wet or direct?
Old Jan 30, 2008 | 04:47 AM
fast04G's Avatar
higher compression pistons will increase power..but if your running the same afr it rly wont make a big difference. especially if your valves and cams are stock.
and if your gonna use nos..go direct port injection
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
as25656800
Aug 9, 2015 07:25 AM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
lemmy999
Jul 25, 2015 12:13 PM
