more power after 100mph...?
Old Feb 6, 2008 | 09:26 PM
Nismo G's Avatar
Originally Posted by BlueDevilBAMF
The Technosquare info or the after 100mph thing? 'Cuz the after 100mph thing makes no sense, but the Technosquare stuff seems feasible to me.
The after 100mph thing isn't true. What it is - is the fact that you are pretty high in the RPM range through 4th, 5th, and 6 gears (probably 4K rpm's + on each gear) and the throttle body flap (butterfly) starts to close the closer to redline you get.
The technosquare information is 100% true. But what i just wrote is probably what that guy is talking about.
-Sean
Old Feb 6, 2008 | 10:57 PM
OCG35's Avatar
Originally Posted by 04-6speed-sedan
who is osiris? and has anyone else done this?one more thing i had my timing advanced by 2* if i disconnect my negative battery cable will it make my timing go back to stock or not? i raced a civic hatch today with a ls integra motor supercharged and pulled on him anyone here race a lot?
search the tuner section - on this forum and on my350Z... there is a ton of info. And yes many of us have done it.
Old Feb 7, 2008 | 11:09 PM
DaveB's Avatar
I don't anyone has confirmed that having the throttle slowly close as the engine exceeds 6200rpms is really a bad thing. The VQ35De intake manifold starts loosing steam at 6200rpms and that doesn't seem to matter whether the throttle is 80% open or 100% open. IMO, it's a safeguard to keep the engine from running excessively lean in the upper rpms.
Old Apr 3, 2008 | 10:17 AM
SDGenius's Avatar
^^^i just had the Technosquare reflash+dyno tune, i can rev to 7100RPM and i won't lean out... no one should do throttle body mod with out a tune or atleast a basic reflash
vamarris
Sep 26, 2015 12:56 PM
zcherub
Sep 10, 2015 12:03 PM
