ECU Reset - Dyno Results
Old Mar 21, 2004 | 03:23 PM
BigmikeOC's Avatar
Re: ECU Reset - Dyno Results
I'd imagine that your car would have more power before a reset unless you were resetting for some mods you added. At least that is what happened on my WRX with a stock ECU , you would lose power after a reset and it would take about 200 miles before it felt like it was back.
WRX guys were resetting their ECUs all the time because they were using piggy-back computers that would eventually cause the car too lose power as the stock ECU learned around the mappings in the piggy-back. Do a reset and blamo...more power becuase the timing and fuel changes are all piggy-back. Two weeks later, down to stock ECU power since it learned around it...reset and the cycle starts again...
This was even mentioned in a Sport Compact review of the Vishnu Stage Zero kit which uses a piggyback ECU. The dyno showed a drop in 10 HP after the reset.
Hope that's not too confusing...
Old Mar 21, 2004 | 05:27 PM
khsonic03's Avatar
Dude, not the case with the G35
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways
Old Mar 23, 2004 | 10:23 AM
BigmikeOC's Avatar
Umm, not the case? Maybe I'm not reading those dynosheets properly but to me the curve for the pre-reset run looks better than the curve for the post-reset run.
Old Mar 27, 2004 | 03:29 AM
blksnake's Avatar
smcallis,
Thanks for sharing your dyno. Overall, I agree with you.
BLKSNAKE - '04 G35 Coupe
Check out my hidden sub! [img]/w3timages/icons/laugh.gif[/img]
Old Mar 28, 2004 | 12:40 AM
g35mt's Avatar
You analysis does make sense. If i understand correctly, the only time you should reset the ECU is new mods?
If you are a xyz company that come out with a turbo, would this data significantly be important to you?
g35mt
Old Mar 28, 2004 | 03:15 PM
G35_TX's Avatar
Everytime I have done the ecu reset lately, my car feels weak for a while, then it gets really strong again. I personally think the ecu reset isn't a good idea unless you have some new mods installed and let the ecu relearn everything again.
Old Mar 28, 2004 | 03:44 PM
Sinurgy's Avatar
It may be possible the car became stronger after a reset but I've seen so many instances where people dyno their car 5 times in a row and get that range of results you got without doing anything to the car.
BS 6MT/Premium/Navi/%5 Tint/Escort 8500/12' Rockford Fosgate Sub/Borla Exhaust
Old Apr 6, 2004 | 01:24 AM
SDGee's Avatar
I did the ECU reset disconnected the bat for 24 hours after my Borla TDE and Hyper Grounding Kit install. I never did it after the ZTube and Pop charger install. Should I do it? I'm going away on a business trip for a few days so I won't need the car. Yall think it will make a dif? I've been driving the car with the pop charger for over a week now. Has the ECU already learned what it needs to?
Black on Black 6MT W/Clear Corners & PIAAs
Borla TDE
Hyper Grounding Kit
Z Tube/JWT Pop Charger
Custom 19s
Old Apr 6, 2004 | 09:12 AM
jjellyneck's Avatar
On my 6MT coupe, I installed a Borla and cats at the same time--I did not reset the ECU. At first, the car ran slightly worse and had noticeably less power. After 100 miles of light-medium driving (in terms of aggressivenes with the throttle), I began to notice power gains over the stock setup. After maybe 150 miles it smoothed out and ran great!
jjellyneck
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
MThawkins86
Oct 24, 2015 02:07 AM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
