Overfilled oil and now burning oil smell wherever I go
Mar 14, 2008 | 11:35 PM
Help! My dad put some extra oil into my g35 due to a long road trip we were taking without telling me. Either he spilled some or he overfilled (or both). Anyways now everywhere I go the car smells like burning oil. I have put almost 800 miles on it and it is still burning oil somewhere. I even see small amounts of smoke after a long drive. How can I fix this?
Reply 0
Mar 15, 2008 | 12:56 AM
Just check your level now and make sure it is at the correct level. Remove oil if necessary. The burning smell is probably oil on your exhaust burning off. It will go away. No big deal.
Reply 0
Mar 15, 2008 | 02:02 AM
id remove oil befor you blow you gaskets!!!!do this...NOW..if theres alot of extra oil the pressure will cause blown gaskets..easy fix...just take some out or rechange your oil and put the right amount in
Reply 0
Mar 15, 2008 | 02:20 AM
^very true...you're going to cause a very expensive problem if you already haven't. also, many cars run sluggish when they are overfilled with oil.
Reply 0
Mar 17, 2008 | 12:04 AM
How can I check for blown gaskets? If I can't do this how much would something like this cost?
Reply 0
Mar 17, 2008 | 12:08 AM
take it to the dealer and ask them to check for you. make sure your oil level is where it is supposed to be before you take it in.
Reply 0
Mar 17, 2008 | 12:32 AM
Can I trust the dealer to not lie to me and want to replace gaskets that are good to go. I take it these are the head gaskets?
Reply 0
Mar 18, 2008 | 07:46 AM
Quote: ^very true...you're going to cause a very expensive problem if you already haven't. also, many cars run sluggish when they are overfilled with oil.
Even worse, if the oil is overfilled enough to contact the bottom of the crank it will aerate (often ~1qt over). Once air is entrained in the oil there is no easy way to get it out - it must be changed. Aerated oil is very bad.
Reply 0
Mar 18, 2008 | 07:51 AM
Is oil leaking on the ground or around the engine block? If not, then your gasket seals are fine.
If you are too high on the dipstick, drain and refill the right amount.
Otherwise, oil spilled onto the exhaust components will burn off eventually...
Reply 0
Mar 18, 2008 | 01:13 PM
well, some leaks will only do so when there is pressure in the system. if you have a leak and are smelling burning oil, the leak may be above an exhaust piece and not drip on the ground.
if you need a reference to a good infiniti service dept., ask the guys one here about the dealers in your area. if you are out of warranty, go to a trusted local shop. look one up online on a customer satisfacton site or local bbb.
Reply 0
