04 Coupe Has A Clicking Sound
Old Mar 22, 2008 | 09:22 PM
amoreno35's Avatar
Yeah My G Coupe Has A Clicking Sound In The Rear Driver Side When I Accelerate. When I Heard It I Started To Worry Wut Could It Be... Please Help!
Old Mar 23, 2008 | 01:55 AM
GrayG35's Avatar
engine knock? sticking lifter maybe? too loud to be the injectors im guessing. take it in for service it should still have engine/driverterain warranty.
Old Mar 23, 2008 | 01:59 AM
jjyellow's Avatar
There is a TSB on this for the 03-04 coupes I believe. Ive had it done on my car. It has something to do with the nuts on the axles I believe
Old Mar 23, 2008 | 02:04 AM
TBG_Dad's Avatar
rear driver side?
I had the same problem. I was told it was something in the rear axle that needed to be lubed back up. Covered under warranty so I dont know how much it costs outside of it. That was over a year ago and no clicking since.
Old Mar 23, 2008 | 02:07 AM
amoreno35's Avatar
im still under warranty.. so ill make an appointment to go get it check out thanks guys
Old Mar 23, 2008 | 02:35 AM
EvolutionGSR's Avatar
Yah i had the clicking. You can make it click by going forward and backward. its just something that needs tightening.
Old Mar 23, 2008 | 02:36 AM
Jpalta01's Avatar
That would the axle nuts that have backed off ever so slightly. Knock the wheels off, pull the cotter pin out, and retorque the axle nut. Once the rear end loads up, you will hear that clicking if the axles have loosened up.
Mine was doing the same thing, but after retorquing the nuts, it was gone.
Old Mar 25, 2008 | 09:00 PM
amoreno35's Avatar
hey guys went to get that clicking sound checked off.. well they adjusted my aligment in the rear cause it was all out of wack.. and the noise went away! total shocker..
TWASkyliner
Feb 8, 2020 08:00 PM
mjfenix
Aug 17, 2017 05:49 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
kd03g99
Jul 30, 2015 11:24 AM
papo020
Jul 17, 2015 10:30 PM
