Ok this isn't normal..why is my fan
Old Apr 2, 2008 | 03:02 PM
dahurt45's Avatar
turning on while I am driving?? I never used to hear my fan until recently..does anyone have any idea why it would be coming on? I've only owned my G for about 5 months..06' sedan..
Old Apr 2, 2008 | 03:03 PM
BlueDevilBAMF's Avatar
... it's getting warmer outside?
Old Apr 2, 2008 | 03:05 PM
dahurt45's Avatar
It is
40 degrees today..no reason my fan should be turning on..I literally just drove it for about 2 minutes and the fan came on..
Old Apr 2, 2008 | 03:09 PM
istan's Avatar
The system is getting hot for whatever reason. Try bleeding your coolant incase there is a bubble and causing the temps to rise higher than normal
Old Apr 2, 2008 | 03:10 PM
dahurt45's Avatar
shouldn't my meter in my car be reading hot
or not? I have no clue how to do that...I assume this would be covered in my warranty?
Old Apr 2, 2008 | 03:16 PM
istan's Avatar
If you trust your dealer more than yourself, yes.
Old Apr 2, 2008 | 03:17 PM
dahurt45's Avatar
By bleeding my coolant
do you mean just draining it and refilling??
Old Apr 2, 2008 | 03:42 PM
istan's Avatar
Search for a DIY on Air Bubble and Coolant
Old Apr 2, 2008 | 04:28 PM
ttrank's Avatar
Grocery getter
Is your A/C on? I know it's not cold but the auto climate uses the A/C to remove humidity too. That will also turn on the fan.
Old Apr 2, 2008 | 04:34 PM
Skaterbasist's Avatar
Retired SuperMod
That doesn't sound like something you should worry about.
Blue Dream
Dec 5, 2015 10:56 AM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
mattdg35
Sep 14, 2015 11:28 AM
