increase airflow to stock airbox mod pic
04 Black Sedan 6mt / front blinker mod, z tube+k&n panel filter / 18" r/h c2s w/khumos 235/40zr18 / stock airbox mod / s-teins / crank pulley / pre-muffler, what pre-muffler?
[image]url[/image]
<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 04/03/04 11:51 PM.</EM></FONT></P>
Re: increase airflow to stock airbox mod pic
notice in sound? you bet! the subtle stock growl turns into a howl around 4k+, but keep in mind i have the k&n filter and z-tube though
someone did this mod with the stock intake tube and noticed a similiar result, but just probably not as loud as mine.
[image]url[/image]
[image]url[/image]
any other pics from the top?
Thanx
Grounding kit - Yellow Top Optima Battery
350z Pipe / Stillen High-Flow-JUN Flywheel
Crawford Intake Manifold V5 Black-High - Flow cats
Nismo Clutch
Best 1/4 14.153 @ 99.19 / 2.29 - 60'
Thanx
Nismo Clutch
for those who are interested, my impromtu mod writeup and a couple of more pics. like to thank g35Mark for posting pics for me. computer illiterate w/heavy right foot :>
https://g35driver.com/forums/showfla...ed&sb=5&part=1
[image]url[/image]
<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 04/05/04 09:49 AM.</EM></FONT></P>
[image]url[/image]
What you've done makes sense in increasing the intake air available, and I've thought about doing the same thing, but I was going to fabricate a replacement piece for the 'Power Duct' which I think needs to maintain an effective seal against the hood to maximize the 'ram-air' effect. Infiniti put a lot of thought into using the foam and rubber gaskets for this reason. At minimum, I was going to heat and re-shape the Power Duct to smooth out and widen the opening.
Also I thought about running a intake tube to replace the resonator to suck in air from the bottom rather than just removing it, again, with the 'pressurizing effect' when the car is in motion. I got side-tracked when I put in my Pop-Charger and winter, so Kudos for doing this first! Looks good though.
I haven't yet decided whether to re-install my Pop-Charger, or do the above. In theory of course, the larger surface area of the P-C filter would benefit even more, so I may look at doing a modded box for the Pop-Charger (with all that free time I have available[img]/w3timages/icons/tongue.gif[/img])
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
were're on the same wavelenght with regards to adding an intake tube to the bottom, thereby creating an even "pressurizing effect".....when i have more time, i'll be taking that one step further by widening that bottom opening to accept the oem intake tube that's sitting in my garage. whoah, double ram effect!
sidenote: it's the "oscai" version of the intake mod for those who came from maxima.org.
[image]url[/image]
<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 04/08/04 11:05 AM.</EM></FONT></P>
[image]url[/image]
Guest
Posts: n/a
this is probably the dumbest quesetion ever but please don't flame too hard...i was looking at my intake and cant figure out how to get that thing off, it looks like there is two bolt/screws but i cant tell what type of tool i need to get them out. please help. sorry for being a mechanical nooby.
'04 G35C Blk/Graph. 5AT
Prem./Splash/Wheels
Prem./Splash/Wheels
view from top
theres two of those plastic screw/rivets thingy under the plastic sealer......use flat head screwderiver, it'll pop right off.....then remove/peel sealer from the power duct piece and reposition it onto the airbox, done. enjoy.
04 6mt Sedan / stock airbox mod / z-tube / k&n panel filter / crank pulley / 18" r/h c2s / s-tein springs<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 04/09/04 12:00 PM.</EM></FONT></P>
04 6mt Sedan / stock airbox mod / z-tube / k&n panel filter / crank pulley / 18" r/h c2s / s-tein springs<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 04/09/04 12:00 PM.</EM></FONT></P>225533-stockairboxmod003.jpg
Hmmm. My Power Duct has the other type of fastener. Use the tip of a pointed tool or phillips screwdriver to push down on the center, and the fastener lifts right off.
Guest
Posts: n/a
thanks gord, i read his reply and looked at the intake again, and found myself scratchin my head wondering if i was retarded, but u have the same as me, thanks for clearin that up
Prem./Splash/Wheels
Prem./Splash/Wheels
I know this is an old thread, but.....
Does anyone have the pics of the modified stock airbox mentioned in this thread that they can post or email me?
Thanks!
Larry
vr4_larry@yahoo.com
Thanks!
Larry
vr4_larry@yahoo.com
