Unburnt Gasoline in exhaust?
Old Apr 10, 2008 | 12:53 AM
sg83's Avatar
Hi everyone,
I posted this in the general section but figured i'd probably get better responses in here...
I have a '04 Coupe 6MT and it's always had a slight "pulse" while sitting at idle. At first I thought it was my engine but when I parked it in my garage, I noticed that the sound was coming from the exhaust. Also, my exhaust has more soot inside the tips than other Gs I've seen.
Now my first thought was that spark plugs need to be changed (which they did) so I changed them. At the same time, I also installed a 5/16 MD Spacer and reset the ECU. Well my car seemed to idle great when I first changed plugs and installed the spacer but now after about 2 weeks later, the exhaust noise is back and worse than before...
I've been reading and it seems like there's some unburnt gasoline getting through to the exhaust? Also maybe my car is running rich? My car is completely stock other than the Spacer.
Any help is much appreciated. Thanks. BTW, the car has 54k miles on it.
Edit/Delete Message
Old Apr 10, 2008 | 01:57 AM
GrayG35's Avatar
hmm if theres unburnt gas in your exhaust wouldnt you be shooting a little bit of flames on when you get on it? Go get on a dyno and check your afr's.
Old Apr 10, 2008 | 02:13 AM
Canadian's Avatar
Canada, eh?
Yeah there is no way to tell if you're running rich or lean without knowing your A/F. Go to a dyno or go buy a gauge.
IMO I think you're fine, our cars sound sweet at idle stock
Old Apr 10, 2008 | 12:21 PM
Hydrazine's Avatar
And water often comes out of the exhaust when you start it up in the morning.
Water is a product of combustion.
Old Apr 10, 2008 | 12:34 PM
JOKER's Avatar
CLUB MODERATOR
why don't you drill a hole in the exhaust pipe and put a spark plug in there and get your self an afterburner.
Old Apr 10, 2008 | 02:08 PM
sg83's Avatar
Thanks for the suggestion. I think I will go get it checked out on a dyno as that's probably the first thing to check.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
