problem taking off the crush washer????
Old Apr 16, 2008 | 10:53 PM
uhohitzmikeo's Avatar
did anyone have a problem taking the crush washer out of the oil pan screw? i changed my oil about 3 times before and i finally wanted to change it out but it couldnt come out. i sat there for about 15 min but it seemed like it was stuck or something. i just ended up screwing it in.
also if i put the new one in, is there a certain side it goes on, or just any side???
THANKS
Old Apr 17, 2008 | 03:35 AM
Meatshackle's Avatar
Deep Sea Moderator
Sometimes I've had to use needlenose pliers to get mine off.
There's no particular side the new one goes on.
Old Apr 17, 2008 | 12:12 PM
mIKE's Avatar
Originally Posted by HomieG35
^^You can try a flathead screw driver to pry it up some too.
You really should replace the crush washer everytime the oil is changed!
+1
Just put a flat head screwdriver on the edge of it, and tap the screwdriver with another one or a wrench...
Works every time.
Old Apr 17, 2008 | 05:37 PM
thanks guys for the response
Old Apr 17, 2008 | 05:48 PM
sydg35's Avatar
i think in the manual it shows the flared end of the crush washer goes on the flat part of the bolt head.
Old Apr 18, 2008 | 02:02 PM
donricouga's Avatar
What size is the crush washer? I had some available in the garage but they were the wrong size so i had to use the one that was already there.
itschuckster
Jul 25, 2015 08:07 AM
EasySausage
Jul 14, 2015 11:17 PM
