went for oil change
Old Apr 22, 2008 | 02:37 PM
LuXXXz's Avatar
went for oil change
to a jiffy lube------ dont even comment
they changed my oil and i go to start my car and it dies out. and then it wont start for like 5 minutes.
after that it started up and has been fine ever since
could oil change do it????? i have no clue wtf it could be
Old Apr 22, 2008 | 04:46 PM
lexusk8's Avatar
Check your connections on your battery and make sure they're all snug. Are you still on the original battery?
Old Apr 22, 2008 | 04:48 PM
g35man04's Avatar
CLUB MODERATOR
what kind of oil did you put in? you could of got some air in the system some how but dont why that would be an issue or even happen since your car should be off during the change.....
Old Apr 22, 2008 | 04:52 PM
lekker_droom's Avatar
At Jiffy Lube anything is possible.
Old Apr 22, 2008 | 05:03 PM
Deezflip's Avatar
dirty throttle body...
https://g35driver.com/forums/engine-drivetrain-forced-induction/182685-car-shutting-off-start-up.html
It doesn't happen with cold starts but it'll stall on warm start-ups once you disconnect the battery with a dirty throttle body, if jiffy lube disconnected the battery at one point.
Old Apr 22, 2008 | 05:12 PM
ttrank's Avatar
Grocery getter
Scary. I wonder if they didn't your oil cap back on the first time around or even worse, didn't put oil in the car! Cars will run without new oil for a short time...
Old Apr 22, 2008 | 06:23 PM
LuXXXz's Avatar
thats the only thing the dipstick didnt have too much oil on it before hand. so im assuming the oil consumption issue. i didnt check it in a while. i usually do maintenance myself. this time i had it done at jiffy lube cause i didnt feel like doin it.
but the only thing is it hasnt happend after that time at all.
i think it might be that throttle body
ill check it out today.
thanks for info guys. if there is anything else i can check for please let me know.
you guys are the best!!!!!
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
