changed oil with 5.75 qts?
Too much? I know the most popular number is 5qts. but I dumped in 5.75 qts while changing the oil today and I know the dip stick is difficult to read sometimes, but i'm fairly certain that it is only a little below the Full mark.
What's the avg you all are dumping in your G's? 5.75 too much?
6MT Coupe
Oil change with filter is 5qts.
Oil change with no filter is 4 5/8qts.
Mine always goes to F mark with 5qts and filter change.
That info is in your manual under 'techincal and consumer information' section. Sub cat 'capacities and recommended fuel/lubricants'.
sorry guys, i totally forgot, i ran about half a qt through my motor after i drained my oil just to run out some extra bad oil, so really I only dumped in 5.25, around that number, so i'm fine. Sorry for the trouble.
You should realize that going with a little less oil is better than going with too much. worry when you are a quart short, but if you overfill with a quart, you run the risk of permanently damaging your engine.
yassy
Aug 9, 2015 07:31 PM
