Hyper Ground Resource Thread
Old Apr 19, 2004 | 08:40 PM
Msedanman's Avatar
O.F. Administrator
Re: Hyper Ground Resource Thread *DELETED*
Post deleted by dyenboy
Old Apr 20, 2004 | 07:18 AM
zimbo's Avatar
Ok, since that other thread was removed, I'll post my picture here. As I promised gordgee I would do (if you missed my challenge in a previous thread well that's too bad), here is the GroundingGear on my supercharged G35 sedan:
Old Apr 20, 2004 | 07:28 AM
cato's Avatar
SouthernComfort Moderator
Did you notice anything after you installed it?
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old Apr 20, 2004 | 01:18 PM
hooner67's Avatar
Guys, Can you give me length of each cables??
Thanks.
Old Apr 20, 2004 | 02:34 PM
SDGee's Avatar
Hi there gsedanman,
I'm sorry to bug you but the resource thread is gone. I bought the 5 wire grounding kit from stillen a while back and put it on. I noticed no diff. I have been reading your posts about the development of an improved system. I am interested in your system. Can I just add the additional wires to the stillen system? Or do I need all new wires? Did you do a before and after dyno? What dose your butt dyno tell you? What type of improvements if any will I notice with your system vs. the Stillen system? Sorry for all of the questions. I usually try to do a search and answer my own questions but I can't seem to find the answers.
Thanks in advance,
Eric
UR pulley soon
Thinking about the TechnoSquare ECU after UR install
Black on Black 6MT W/Clear Corners & PIAAs
Borla TDE
Hyper Grounding Kit
Z Tube/JWT Pop Charger
Custom 19s
Old Apr 20, 2004 | 03:43 PM
ryoken's Avatar
SDGee:
You want gordgee, not gsedanman. Try sending him a PM with your question.
Old Apr 20, 2004 | 04:03 PM
gdupg35's Avatar
Post deleted by dyenboy<P ID="edit"><FONT class="small"><EM>Edited by dyenboy on 04/21/04 10:23 AM.</EM></FONT></P>
Old Apr 21, 2004 | 01:22 PM
dyenboy's Avatar
Registered
We are trying to ressurrect the orginal resources thread. In the mean time, please use this thread.
Once again, I apologized for any inconvience.
Old Apr 21, 2004 | 04:30 PM
Ventural's Avatar
Florida G35 Club Charter Member
Pic of GroundingGear™ on 2004 G35C 5AT.
Old Apr 21, 2004 | 05:56 PM
S2000rs's Avatar
does anyone know the lengths of each cable? where can i buy 4 guage wire?
Old Apr 21, 2004 | 06:12 PM
S2000rs's Avatar
yes, please put the old thread up, it was pretty useful. Thank you!
Old Apr 21, 2004 | 11:43 PM
Z2G's Avatar
Z2G
from what i remembered, i don't think you're going to get any measurements information on that thread--only dyno results and install instructions, my friend. the exact measurements and locations for install was all protected by copyright, i believe.
Old Apr 22, 2004 | 06:50 AM
cato's Avatar
You can buy 4 gague wire at any electrical supply shop.
I bought enough to make 4 additional cables to add to my
Grounding Gear 10 wire set. I don't remember the lengths
of the wires. But you can measure them yourself, Look at the
posted pic of Gordgee's basic 7 wire set and measure the
length of string it takes to reach.
Old Apr 23, 2004 | 12:44 PM
cnts13's Avatar
I do not know if this is the information in this has changed or not. It was originaly taken from a post by "gsedanman" on 5/21/03 in the original thread (So it's fairly old).
Old Apr 23, 2004 | 12:54 PM
cnts13's Avatar
The picture that I attempted to attach was too big. Here are the details from gsedanman's original scanned image:
#1 - 16" - Left side of intake manafold to front of the engine.
#2 - 19" - Left side of intake manafold to left side chassis ground.
#3 - 29" - Rear left of intake manafold to front of engine.
#4 - 30" - Left side of intake manafold to the negative connection of the battery.
#5 - 32" - Rear right of the intake manafold to the front of the engine.
#6 - 30" - Rear right of the intake manafold to the front of the engine.
He did not yet have a measurement for wire #7.
Just relaying some history from a post that I had saved from months ago. Use the info for what it's worth, no warranty implied.
<P ID="edit"><FONT class="small"><EM>Edited by cnts13 on 04/23/04 01:17 PM.</EM></FONT></P>
