Need some suggestions, Thanks a lot!
Old Jun 13, 2008 | 12:36 PM
mashimario's Avatar
I just got a 2003 G35 Coupe A/T w/ 76k miles. I am not sure if the older owner has already done the 60k maintenance or not, probably not. I am planning to do that. Basically, the following is the list in my mind.
1) Change the engine oil and oil filter w/ mobil 1 oil and filter
2) Change the transmission fluid w/ Nissan Matic J fluid. Should I ask the dealer to do a fully flush or just DIY drain and refill? If the latter, how many qts do I need?
3) Change the engine coolant w/ Nissan Coolant. Same question, should I do a fully flush or just drain or refill the radiator?
4) Replace the drive belt. Is it necessary? If yes, which drive belt you will suggest?
5) Change In-cabin microfilter
6) The old owner put in injen air intake, so I don't need to replace the air filter, do I? Actually, I didn't see the air filter house...
7) Old owner just replaced the front rotors and pads. I will replace the rear pads w/ Hawk and resurface rotors.
Is there anything I need to do?
Thanks a lot, guys.
Old Jun 13, 2008 | 09:17 PM
mashimario's Avatar
no one can help me?
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Forced Induction
Sep 4, 2015 12:11 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Nick_M
Aug 6, 2015 06:29 AM
