Want to Put on new headers??? I'm a Rookie
Well guys I'm a crazy G35 fanatic just got into fixing up my ride and now I'm focusing on performance. Getting to the point, I was wondering if any of you Pros could help out a rookie and tell me or send some pics of your rides with new headers I kinda have an Idea but I don't want to mess anything up with the engine being so expensive and my income being so low Lmao!!!
Anything would help thanks a lot.
Headers are definitely worth doing, but they have to be on non-REVUP motors to do much good. The variable exhaust motors/ECU are programmed/designed for the stock manifold flow/velocity characteristics. Headers just mess things up on those. If your car is a non-REVUP, it may be worth it along with a tune afterward. Just don't try installing yourself. Get ready for a $400 install bill.
Originally Posted by Jeff92se
ballistcus. tell me about your stillen gen 1 modified exhaust.
Originally Posted by Klubbheads
Why is that?
When you bolt on a header designed around fixed exhaust timing onto an ECU controlled cam, now it is attempting to "correct" the torque curve, but it can't due to a completely different pulse/scavenging effect. I would bet some REVUPS might actually see a loss after adding headers.
Damn you guys know what you're talking about I did a little research myself got laughed at, guys at shop told me to start simple then work my way up to the top like all of you guys thanks for da advice.
jbmw002
Sep 10, 2015 12:54 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
.............Just do it.....but DONT install it your self...
