Putting engine cover back on and...
Old Jun 27, 2008 | 12:19 AM
mchamps's Avatar
I just installed a Z-Tube and a JWT Pop Charger, and while putting in the last screw on the engine cover (driver's front) I think I may have stripped the threads, not on the nut but the block.
Is there a fix for this?
Old Jun 27, 2008 | 12:23 AM
SteveBlake's Avatar
i just kept the engine cover off.
Old Jun 27, 2008 | 12:26 AM
mchamps's Avatar
I want it on though. or should I just kinetix upper plenum FTW?
Old Jun 27, 2008 | 12:29 AM
partyman66's Avatar
It's not the block... it's the plenum.
I wouldn't worry about it. You'll run a greater risk of screwing something up if you try to fix the plenum, so your best bet is probably just to remove the whole engine cover so that it doesn't run a risk of rubbing a hole in the heatshield of the hood.
If you really care a lot about it and want to use the cover still, you could go buy a tap set or a thread chaser and try to make some new threads in the plenum and put the next size up of a screw back in as a replacement for the stock one.
Old Jun 27, 2008 | 12:31 AM
SteveBlake's Avatar
kinetix upper plenum FTW if you want to pay over $500 for no gains...
If you really want the engine cover back on just leave the three screws that work, tightened and the stripped one empty.
Old Jun 27, 2008 | 12:32 AM
gary c's Avatar
The key to all those nuts/bolts is not to over tighten them....just snug!
"NEW RECOMDATIONS!" Just run a new bolt down the hole
I'm sure any Nissan dealer will have one.
See Blue I fixed it....LOL
Old Jun 27, 2008 | 12:39 AM
BlueDevilBAMF's Avatar
^^^ OMG Gary you forgot your bolded post subject line!!!
Keep the engine cover off and get a polished plenum from sxecex or whatever his name is lol
Old Jun 27, 2008 | 12:40 AM
mchamps's Avatar
now that I think about it...I did over tighten it. That's why it's effed.
Old Jun 27, 2008 | 12:42 AM
mchamps's Avatar
how much is he slanging them for?
Old Jun 27, 2008 | 12:48 AM
Not certain... they look really good though, that's for sure. Great way to dress up an engine bay.
Old Jun 27, 2008 | 12:51 AM
mchamps's Avatar
Originally Posted by gary c
The key to all those nuts/bolts is not to over tighten them....just snug! Flip
the screw over so the part that was in the block is now on top. Screw the
nut down tight, now using your 10mm socket/ratchet cut new threds....carefully. Do
you understand what I'm telling you to do? Now you should be able to
reinstall the cover without any issues...remember just snug.
i'm not sure i'm following here.
Old Jun 27, 2008 | 12:54 AM
partyman66's Avatar
If you really care about it that much and want a clean OEM repair, you could also try to buy a used OEM plenum from someone with an '03 or '04 G35 Coupe who has already upgraded to an aftermarket one. I bet you could get it for a not too ridiculous price.... but I still say it's not worth it just for an engine cover that many people remove anyways.
There's a ton of people with aftermarket plenums.. just ask around or make a WTB post in the appropriate section of the forum.
Old Jun 27, 2008 | 12:55 AM
partyman66's Avatar
Me either.
Old Jun 27, 2008 | 12:57 AM
SteveBlake's Avatar
Dude.... you're right!
