starting problem...
Old Jun 29, 2008 | 10:41 PM
shyger85's Avatar
starting problem...
sometimes when i start my car it seems like it doesnt give any fuel and the car wouldnt start..i have to take the key in and out of the ignition like 5 times and keep stepping on the clutch for it to start..man im getting fed up with this s$$t..please need help...thanks..
Old Jun 30, 2008 | 04:13 PM
MyOtherCar_GT-R's Avatar
What does it sound like?
Old Jul 1, 2008 | 12:18 AM
shyger85's Avatar
theres no noise at all just seems like no fuel coming through then after stepping on the clutch like 5-6 times and then the car will start up..it just happens every other start ups..****en geezer..
Old Jul 1, 2008 | 08:53 AM
I don't think it has anything to do with the fuel. It would make noise some type of noise if it was trying to start.
The clutch needs to be fully engaged to start the car. So it sounds like the sensor that tells the car the clutch is engaged is bad. Not really sure about the mechanics. Maybe someone else can jump in and give you more details.
Old Jul 1, 2008 | 10:55 PM
shyger85's Avatar
yes i step on the clutch all the way..it might be what you said about the sensor thing how or where do i check for that sensor..???thanks..
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
Gwhut?
Sep 4, 2015 11:10 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
